The garage
Water leak
Topic: Water leak (Read 3757 times)
AdamB
The Perfect Storm
Water leak
02 November 2003, 19:10 »
I have found the side water housing on the engine is leaking very slightly, can I just seal it with some type of sealant? or is it a bigger job?
I don't own this anymore - I just can't be arsed to change the picture
golfvr6
Guest
Re:Water leak
02 November 2003, 19:14 »
You should be able to take it off and put some sealant round it. I think it should have an o-ring seal already, that may be knackered.
mk1
2ltr16v turbo (now with programmable EFI)
Re:Water leak
02 November 2003, 19:20 »
Is it a black plastic housing?, if so check for cracks in it as they are prone to cracking. New ones are not dear.
Steve.
http://www.geocities.com/mk1turbo16v/golf_turbo.html
AdamB
The Perfect Storm
Re:Water leak
Cheers '6.
Mk1 - the leak is coming from where the pipe goes into the engine block, I am guessing its just a seal gone.
Last Edit: 02 November 2003, 19:22 by AdamB
Blue MK2
Guest
Re:Water leak
02 November 2003, 23:48 »
Mine leaks but how can i cure this? (the part pointed out) It leaks where it is attached to the head and ive tried to tighten it with no effect.
golfvr6
Guest
Re:Water leak
04 November 2003, 00:05 »
Take the elbow piece off, clean it up , check it isn't cracked, then replace the o-ring seal.
Blue MK2
Guest
Re:Water leak
Reply #6 on:
04 November 2003, 22:06 »
Is the O ring easy to replace? How much from VW?
richandhazel
Global Moderator
Forum addict
Re:Water leak
Reply #7 on:
05 November 2003, 14:33 »
Simple job, exactly as vr6 says. O ring sould only be a few pence.
AdamB
The Perfect Storm
Re:Water leak
Reply #8 on:
05 November 2003, 15:37 »
Mine is leaking from just round the right hand side of Blue mk2 pointer. Its a similar size pipe going in to the engine.
richandhazel
Global Moderator
Forum addict
Re:Water leak
Reply #9 on:
05 November 2003, 15:42 »
Hi Adam,
The same applies.........
The garage
Water leak
