Author Topic: odimeter  (Read 2339 times)
Offline dubslug
odimeter
« on: 02 November 2003, 15:22 »
on my 1989 1.6 driva, the mailage dont move nor does the trip counter any ideas??
speedo and everything else works fine
1992 pearl grey 8v
golfvr6
Re:odimeter
« Reply #1 on: 02 November 2003, 18:06 »
I think you will have to take all the dash out, as one of the cobs is probably broken.
Offline dubslug
Re:odimeter
« Reply #2 on: 02 November 2003, 23:47 »
sorry but wot do u mean when u say cobs golfvr6?? or anyone??
1992 pearl grey 8v
Offline AdamB
  • The Perfect Storm
Re:odimeter
« Reply #3 on: 03 November 2003, 07:56 »
may mean "cogs" on the back of the speedo - they will be obvious when you take it apart
I don't own this anymore - I just can't be arsed to change the picture
Offline dubslug
Re:odimeter
« Reply #4 on: 03 November 2003, 18:16 »
thanks adam, is it a difficult job to do??
are cogs available??
1992 pearl grey 8v
Offline AdamB
  • The Perfect Storm
Re:odimeter
« Reply #5 on: 03 November 2003, 18:24 »
Once you have taken the instrument pod out, you should see half a dozen 8 or 10mm hex screws holding the thing together. Just start taking it apart and it should all become fairly self evident as to what is wrong, the odometer is a single unit in itself. As well as the cables that are plugged into the back, you will need to unclip the speedo cable to the back of the pod to remove it, this requires nimble fingers! - just be careful not to damage the circuitry on the flexible circuit board on the back of the pod.
Offline dubslug
Re:odimeter
« Reply #6 on: 03 November 2003, 18:31 »
wish id known this yesterday as i had the damn thing out. never mind will take it all apart again soon
1992 pearl grey 8v
