Author Topic: how do people make the back wheels stick out further than the front??  (Read 2452 times)
Offline GolfGTiMk216LoveIT
 :shocked: how do people make the back rims stick out more than the front is this hard and will i need extention work or is it just a case of getting different et set ups??? :shocked: plz help
Offline Mr Blue
9'' wide on the back and 7's on the fronts :smiley:
add spacers and u can push the rears out even more
i reccomend 9'' wheels all round :cool:
Offline Agreeable Slick
  • Unit
i don't cos you end up going slower.
oh and spacers. Or a low offset.
wot do u mean slower? :cry: still dont quite understan and will i have to have archwork?
Offline Mr Blue
just for looks mate :smiley:
  • Unit
think about it, you are bolting 9" of cast ally onto your driveshafts each side. Now you also have a 9"wide tyre in contact with the road. In order to move you need friction. The amount of friction you are going to get from them is going to cause them require more power to get them moving and keep them moving. Hence killing your power output and making you travel slower.
Archwork, yes, as i said before anything larger than a 7.5" wide wheel is more than likely to require arch work. especially at the fronts. As it needs to be able to turn within the arch without fouling either your driveshaft or your arch. At the rears if you fo for 9s then definately you will need to remove the lip and get it rolled. Removing the lip will require the arches being seam welded back up as they are made of 3 skins. If you don't do this the inside of the arch will rot away.
as blue mentioned, for looks yeah great, they look fat, if you want to keep a good speed level up then smaller alloys the better.
that sux i enjoy the speed to much !!! i am looking at getting some borbit A class what do u think i should get to make it look good but still have the speed any other alloys can u think of to reccomend i have about 800 to spend??
  • Unit
if your getting borbets and want them wide at the rear then look for a set to buy from germany. Muchos cheaper and will leave you with about 500 to use on archmods.
Other than that, i would say stick with a set of 7/7.5s at front and rear. Much easier to play with and won't require much modding.
I like ronals: turbos and LS,
BBS Splitties of any flavour,
Schmidt Modernline,
