Author Topic: Mk2 4 light Debagde grill  (Read 2314 times)
Offline capoot
  • Mk1 Skoda Octavia VRS
« on: 17 November 2005, 16:56 »
Will this fit, i found a guy in germany who sells this, but it looks like theres a bit off the bottom missing?!
Look
what you guys think?
Thanks Dan
Offline Agreeable Slick
  • Unit
Re: Mk2 4 light Debagde grill
« Reply #1 on: 17 November 2005, 16:58 »
i think you are correct.
Offline Haribo!
« Reply #2 on: 17 November 2005, 16:59 »
yeah the bit where the metal part clips to the bottom looks missing, maybe it attaches a different way?
Offline Haribo!
« Reply #3 on: 17 November 2005, 17:00 »
then again i cant remember fully but i think its supposed to look like that without the metal part.... i cant remember grr im sure someone will
  • Unit
« Reply #4 on: 17 November 2005, 17:04 »
incorrect. Behind the metal bit there is a little peice of plastic with little slots and bits of plastic sticking out, the metal bits has little bendable metal slots which go through the plastic mounts and then bend round to lock in. That one looks like it doesn't have any of the above.
Offline capoot
« Reply #5 on: 17 November 2005, 17:05 »
is the metal bit the part under neath the grill on this pic?
Offline Haribo!
« Reply #6 on: 17 November 2005, 17:06 »
ta, i was right the first time then, it does look like it has something there instead tho, i wouldnt buy it anyway, better off making your own :) then you know itll fit properly
Offline Haribo!
« Reply #7 on: 17 November 2005, 17:07 »
yes, it comes off
Offline capoot
« Reply #8 on: 17 November 2005, 17:08 »
Rite then! is it easy to get off and haribo, you sed u made ure own!! Fancy doing me one as im at uni and i dnt get home often!?  :grin:
Offline Haribo!
« Reply #9 on: 17 November 2005, 17:10 »
yeah sure but i dont have any parts, grills ect, if you can send me a couple of grills i can make you one, as the scrappys round here are short of golfs
