Golf mk2
igntion swtich or Barrell ?
Topic: igntion swtich or Barrell ? (Read 1306 times)
Diluxe
Here all the time
16 November 2005, 09:16 »
I need to push my key hard into the barrell & then turn the key to start the car, if i dont push it just turns over and wont fire, is the switch or the barrell thats gone?
cheers
1997 16V
VeeDubGTI16v
Guest
Re: igntion swtich or Barrell ?
16 November 2005, 10:08 »
its probably the bit on the end of the barrel that turns the switch. I had that problem when i put a gsf barrel on mine and it rounded off in a matter of weeks
its probably worn away a bit
Diluxe
Here all the time
16 November 2005, 10:36 »
can i get a barrel to match the key i already have or will i be that guy that walks about with a key for each lock on the car
1997 16V
rubjonny
10k hero
Hello, my name is John and I'm a dub addict.
16 November 2005, 11:49 »
Try the ignition switch first
VeeDubGTI16v
Guest
16 November 2005, 15:33 »
you can take the barrel apart and use the new end with the key on it that fits into the ignition switch and screw that onto your old barrel
Diluxe
Here all the time
17 November 2005, 08:32 »
Intersting, cheers for that bit of info, i'll see how much a barrel is from local ECP.
1997 16V
Golf mk2
