Author Topic: new engine mounts now vibration between 2000 - 3000 revs?  (Read 815 times)
Offline Diluxe
Hey all, got a strange problem with my 16v, fitted a new set of engine mounts & now i'm getting vibration between 2-3k with or without the car in gear, any ideas whats going on? could  have fitted something the wrong way round are the new mounts fooked?
cheers
1997 16V
Offline KKK
Re: new engine mounts now vibration between 2000 - 3000 revs?
« Reply #1 on: 11 November 2005, 17:58 »
Yeah, my  new engine mounts vibrate more too.  Dunno why.
Offline Diluxe
« Reply #2 on: 11 November 2005, 21:47 »
it seems i had subframe bolt that was loose, which was causing the whole car to shake, better but still not as before , where yours from GSF too?
1997 16V
Offline Gambit
« Reply #3 on: 12 November 2005, 14:34 »
also check the gearbox mount bracket. the two bracket bolts that go onto the gearbox end of the bracket are usually put in back to front and then rub against the chassis
