Author Topic: power steering pipes  (Read 1675 times)
Offline VR6_ROB
  • Mk2 VR6 / Corrado G60
« on: 09 November 2005, 19:23 »
I am swapping my power steering pipes putting vr ones in my rack
one bolt is screwed on the gti pipes that are still in but i got one out
but i noticed half way up the pipe it goes thicker
and they is some sort of small metal cover where it changes
from thin to thick can these be removed as i aint seen out like it before
and if it can i could change thta pipe halfway
Judderi
Re: power steering pipes
« Reply #1 on: 10 November 2005, 14:08 »
You gotta start taking pics rob! Might help with getting an answer.
Offline VR6_ROB
« Reply #2 on: 10 November 2005, 18:05 »
lol i dont have a digi camera or a camera phone
id better get summat
Offline VR6_ROB
« Reply #3 on: 10 November 2005, 21:07 »
ok here is a pic of what i am on about
can this be split apart here
Judderi
« Reply #4 on: 11 November 2005, 08:50 »
I dont think  you would be able to split that join, but i dont really understand why you would want to anyway.
Offline VR6_ROB
« Reply #5 on: 11 November 2005, 18:05 »
because the nut is rounded off on the rack
i cant unbolt it to put the new pipes in as they have different ends
so i thought if i could undo that i could attatch new part on to that
then it will go into the pump ok
dunno if that makes sense
Offline Mr Blue
« Reply #6 on: 12 November 2005, 11:57 »
get a pipe wrench on it and buy some break pipe spanners. your gonna need them. :wink:
cant be split apart Rob :nerd:
Offline Gambit
« Reply #7 on: 12 November 2005, 14:20 »
why dont you just cut the rubber pipe and rejoin with a piece of copper pipe and 2 jubilee clips?
Offline Daz...
« Reply #8 on: 12 November 2005, 17:28 »
i wouldnt recommend that with the power steering because of the pressure created in the system when its running..i had a leak on one of my pipes and tried patching it up...i soon found out how quickly the fluid can find its way out of the system!!
08.03.10 - 3, maybe 4 weeks, and I want my golf back on the road!
Offline VR6_ROB
« Reply #9 on: 12 November 2005, 19:59 »
think ill just try some other method of getitn the bolt off
