Author Topic: Locating and replacing VR6 abs ecu  (Read 1265 times)
Offline silverfox
« on: 08 November 2005, 13:41 »
Hi,
I have been told by VW that i have a fault on my ECU and need to replace it.
i have been trying to find the part number for it...
VW say: 3A907379, every web site i have chwecked for ECU's (GSF and eurocarparts, even eBay) the number is 1HO907379C.
Does anybody know the part number i need? are they different between models? ie between GTI, VR6, etc.
Also - where is it? the manual states that a 96 VR6 has the ECU attached to the hydraulic pump, (in the engine bay) but there is a 'box' under the rear passenger side seat, that looks like an ECU to me, with the part number: 1HO927379C.
Confused  :huh:
which part number do i need, and where is the little bugger, if its under the bonnet this is a specialist job, if its under the seat i can do it myself.
Nick
Offline silverfox
Re: Locating and replacing VR6 abs ecu
« Reply #1 on: 16 November 2005, 11:16 »
Anybody - somebody out there must know something about ABS boxes - getting desperate to sort this out.  :sad:
Offline GTI EDITION (aka LTD)
« Reply #2 on: 16 November 2005, 14:02 »
The CURRENT FLOW DIAGRAM (VW) MANUAL  states that from Feb 95 onwards the ABS/EDL control unit is located on the left hand side of the engine compartment ( which I believe is integrated with the valve blocks etc .
Control units (ECU's) for the earlier models were located , separately from the valve block etc. either in the front right footwell or from 01.93 under the rear seat on the right .
( But I have found from experience that some times things are lost in translation when it comes to Left and Right in their manuals  :undecided:
Sorry but I can't help you with the part number for the ECU but hopefully this may have thrown some light on your prob .
Oli  :wink:
« Last Edit: 16 November 2005, 14:04 by GTI EDITION »
http://www.golfgtiforum.co.uk/gallery/thumbnails.php?album=topn&cat=19378
Does my arse look TOO BIG (to fit) in this (forum).... or was it something I said ?
