Author Topic: 2 lt bottom end  (Read 5413 times)
Offline jasonpi
Re: 2 lt bottom end
« Reply #10 on: 15 November 2005, 10:09 »
if the audi 2lt 16 valve is lower hp than the golf 1.8 why go for the conversion did the audi use milder cams? if i put the golf head on will it improve hp?
Offline AudiA8Quattro
Re: 2 lt bottom end
« Reply #11 on: 15 November 2005, 13:43 »
The 9A produced less power than the KR because it had softer profile cams to go with the cat converter that was fitted.
Offline Devon Joe
  • Liebe zum ropey Automobil
Re: 2 lt bottom end
« Reply #12 on: 15 November 2005, 17:20 »
I put the complete Audi engine in and then just swapped the cams afterwards.
As golfvr6-is-back said, the Audi 6a/Passat 9a 16v engines had softer cam profiles and a cat which gave less power and emissions.
Fixing my clutch tonight...
If only my Volkswagen was as reliable as everyone else's...
Judderi
Re: 2 lt bottom end
« Reply #13 on: 17 November 2005, 15:00 »
Does anybody know anything about the 11J bottom end?
