Author Topic: seriously strange starting issue??!!...mk3 1.4  (Read 2020 times)
Offline -HellRaza-
« on: 06 November 2005, 17:42 »
hey
its my brothers car with the issue, its a 1992 1.4 3 door... tis a weird one, basically itll start, but if you start it normally itll conk out imediately, but if you start it, rev it and then turn the key to the off and then quickly to the on position itll run perfectly fine...!! the stater motor is on the way out, i know that as it makes a weird 'errr' noise when you start the car, but that wouldnt cause that sort of problem surely?? any ideas guys??!
cheers
alex
Offline ronnie'C'
  • MKVI GTi and a MK3 VR6 (lhd)
Re: seriously strange starting issue??!!...mk3 1.4
« Reply #1 on: 07 November 2005, 08:11 »
Once you have started the car the 'dodgy' way, how far are you able to travel without the car cutting out or does it not cut out?
Offline -HellRaza-
« Reply #2 on: 07 November 2005, 10:31 »
doesnt seem to no...
alex
Offline ronnie'C'
« Reply #3 on: 08 November 2005, 17:19 »
can't help you then, soz
Offline adyh
« Reply #4 on: 09 November 2005, 09:50 »
hmmmm , try changing the ignition barrel on it . Sounds like a dodgy connection when you turn back down from 2 [?] to 1 .
Offline DUNNY
« Reply #5 on: 09 November 2005, 22:33 »
hi when you take out the igntion barrel check the terminals on the back of swicth as they do have a tendancy to burn out
