Author Topic: 2L 8v  (Read 1913 times)
Offline 1 Lp
2L 8v
« on: 06 November 2005, 07:29 »
HI can any tell any body tell of any problems in swapin over the standard 8v block to a 2E block?? is a 3A block better then a 2E??
Also are their any upgrades that need to be done apart from the head gasket?
How reaible is this swap??
VWs are like women, they need love care and attention
Offline dubslug
Re: 2L 8v
« Reply #1 on: 06 November 2005, 10:47 »
hello mate wot 8v block u starting with??
if u got a digi then its as easy as can be,as long as u have the mk3 block and dizzy, its simply a case of replacing the block and dizzy and then using the reat of the mk 2 stuff, i.e head gear box etc, ive found the 2e block sits abt 16mm higher so u cant use the top cam cover, also if u have a stainless steel exhaust u may foul on the underside of the body work, i havent though
as for head gasket id use the metal one, i used standard one and ripped it apart after 40miles, changed for matal one and now havent had any problems there
also might be worth using an up rated clutch kit, i havent and sometimes the clutch stinks if i pull away to quick, will defo be using a up rated one next time
hope this helps as im still half cut from last night
rik
1992 pearl grey 8v
Offline silkyballs
  • more tea vicker??
Re: 2L 8v
« Reply #2 on: 06 November 2005, 12:17 »
i have the 2ltr mk3 bottom end in mine with mk3 box with a rod conversion to tak a 16v clutch and fly wheel as the 16v is smaller and liter gives it that buit more acceleration!
http://[img]
Offline 1 Lp
Re: 2L 8v
« Reply #3 on: 07 November 2005, 17:19 »
J164, how much BHp does ur motor kick out?? How long have u had this conver??
Offline silkyballs
  • more tea vicker??
Re: 2L 8v
« Reply #4 on: 07 November 2005, 17:38 »
well i put it in the rollers and it was some where between 145 and 150 as it developed a kind of miss fire which im still trying to sort out.mine has had a lot of head work ie; cam,valves,ported skimmed polished and gas flowed.so it not just a standard head.its now done around 9000 miles i got it from a guy off here and he had done all the work it was running on k jet but i changed it to digi.once ive sorted the the prob this week end it will go in for a remap which will boost it hell of alot!
http://[img]
