Author Topic: sunroof setup  (Read 2114 times)
Offline mpgscott
sunroof setup
« on: 30 October 2003, 23:34 »
I have a problem with the sunroof on my 1990 8v gti.
when i got the car it would only tilt and not slide.
If you get someone to push down it would then slide but was very stiff.(lack of use i suppose)
According to the haynes manual there are adjusters, so i removed the sunroof and then the fun and games started trying to get it back together was a nightmare.  I think the diagram is only for a sliding roof.
So now my roof only slides and wont tilt?
The explanation in the haynes manual is poor, can anyone shed some light on how to set it up, or could someone supply a diagram of the tilt and slide assembly.  if so email mark@bridgeend5.fsnet.co.uk
Any help much appretiated
1996 VR6 Highline
2007 Aprillia Tuono
Offline Dizzie
  • Make friends with your fast
Re:sunroof setup
« Reply #1 on: 31 October 2003, 00:03 »
I didnt' think they sold a Golf as standard with a Tilt and Slide sun roof  ???
Offline Gambit
Re:sunroof setup
« Reply #2 on: 31 October 2003, 10:46 »
nope, if you have a tilt & slide then you have an Audi 80 sunroof in yours, common modification
Offline Ant
Re:sunroof setup
« Reply #3 on: 31 October 2003, 12:45 »
Here's an article on the mod, pictures included so hopefully should help you.
http://www.gtiworld.fsnet.co.uk/Tilt_n_slide.htm
