Author Topic: Reverse Light Problems  (Read 1052 times)
Offline mk3miniturbo
  • MMMMM
« on: 31 October 2005, 13:58 »
Hi All,
Just a quick question, my reverse lights are very intermitent and I would love to get them sorted.  Where abouts is the or is there a reverse switch and does anybody know common problems/how to fix it?
Thankyou
Jp
Offline Mr Blue
Re: Reverse Light Problems
« Reply #1 on: 31 October 2005, 15:34 »
reverse switch is on the gearbox just behind the clutch cable if i remember right  :rolleyes:
has wires on it so shouldnt be too hard to find
  • MMMMM
« Reply #2 on: 31 October 2005, 16:32 »
I have now tested the switch with a multimeter and that is OK. The fault is somewhere in the wiring.
Does anybody have any suggestions where there could be a brake? Looks like the earth goes straight to the battery but not sure where the rest goes.
Any ideas would be appreciated.
Jp
Offline eightvalve
« Reply #3 on: 01 November 2005, 09:54 »
THe switch might seem to be ok when you have it out and you're testing it for continuity.  But it can still cause intermittent probs. Buy a new switch from Eurocarparts for £5.74 (inc vat).  The part number is 465550030
1989 Mk2 8v
  • MMMMM
« Reply #4 on: 01 November 2005, 12:10 »
Will give it a go.
Didnt realise it was such a cheap part.
Thanks
Offline Gambit
« Reply #5 on: 01 November 2005, 13:12 »
there is two types or reverse switch depending on your car
pre 89 have a two spade connector
post 89 have a plastic 2 pin connector
