Author Topic: Exact measurements of the mk2 golf  (Read 11910 times)
VR6_Golf_Mk1
« on: 31 October 2005, 12:50 »
can anyone tell me a place to find exact measurements of the mk2 golf (preferably syncro/ rallye) engine bay, overall size, chasis size etc?
would be very grateful.
thanks
Offline gibby
Re: Exact measurements of the mk2 golf
« Reply #1 on: 31 October 2005, 13:10 »
I've got a book that has certain measurements, weights, lengths etc on various models up to mk3, I dont think the engine bay will be one of them though.  :undecided:
Is this what you want ?
Here's the dimensions of a Rallye
Track front           56.3in (1430mm)
Track rear            56.3in (1430mm)
Wheelbase          97in (2464mm)
Length               158.9in(4035mm)
Width                 66.9in(1700mm)
Height                55.1in(1400mm)
Unladen weight   2632lb(1195kg)
mk2 8 valve
Track front                    56in (1422mm)
Track rear                     56in (1422mm)
Length                         157in(4988mm)
Width                           66in(1676mm)
Height                          55in(1397mm)
Unladen weight (3-door) 2026lb(920kg)
Unladen weight (5-door) 2070lb(940kg)
mk2 16v
Width                           66in(1676mm)
Height                          54.9in(1395mm)
Unladen weight (3-door) 2114lb(960kg)
Unladen weight (5-door) 2158lb(980kg)
I'm such a geek ! :laugh: There's no specific dimensions for the synchro so I'm guessing that they are the same as a mk2 but will probably be slightly heavier due to the 4 wheel drive.
If you need anything else give us a shout and I'll see if it's in my bible.  :smiley:
« Last Edit: 31 October 2005, 17:58 by gibby »
......now officially dubless.
VR6_Golf_Mk1
« Reply #2 on: 31 October 2005, 21:19 »
thanks alot.  :smiley:
