Author Topic: oil temp stuff  (Read 982 times)
Offline Chugadub
oil temp stuff
« on: 29 October 2005, 21:50 »
Hi everybody,
Ok well had the car for a month now, and apart from new brake cylinder (old one popped down the m4) everythings fine. Apart from the oil temp, which is really annoying. I cleaned it up and put a new connector on it but still no luck, anyone have any other ideas or know how much im looking at for a new one and where from? Oh and does anyone know of a good scrappy in the Bristol area too?
Thanks.
Cant afford a sig.....
Offline Mr Blue
Re: oil temp stuff
« Reply #1 on: 29 October 2005, 22:46 »
i think the oil temp sensor is the smaller one at the front. Did it ages ago so cant remember well. few quid from VW mate  :smiley:
They can fall into pockets at scrappies so be careful :wink:
Offline Dizzie
  • Make friends with your fast
Re: oil temp stuff
« Reply #2 on: 30 October 2005, 11:02 »
It is the one on the front of the oil cooler as my young padawan Blue points out. The one behind it is the oil pressure sensor. It's likely to be a dodgey wire loose somewhere as the sensors are fairly robust. :D
Mk4 Golf 150PD
Offline Chugadub
Re: oil temp stuff
« Reply #3 on: 30 October 2005, 13:56 »
ok thanks guys, yep i knew where it was and put a new connector on it didnt seem to do anything, i also tried earthing the wire and that didnt bring up a reading either so im outta ideas now. might just try a new one. any further ideas much appreciated!
Offline Volkswagavin
Re: oil temp stuff
« Reply #4 on: 31 October 2005, 09:39 »
My car has the wrong filter housing on it so there is no oil temp sensor on my car, but I'm told by a mate that the MFA will only display the temp within a certain range.  When the engine is cold it will read nothing, then kick in when it reaches a certain temp.
Gav
Mk2 Golf GTI 8v - J reg
Offline Daz...
Re: oil temp stuff
« Reply #5 on: 31 October 2005, 09:45 »
It starts reading from 50c and above I believe...I've got some VDO gauges in mine so I can't remember what the original was.. :rolleyes:
08.03.10 - 3, maybe 4 weeks, and I want my golf back on the road!
