Author Topic: Error codes/ engine missfire !!!!!!!!!!!!!!!!!!!!!!!  (Read 2186 times)
Offline Mr Blue
« on: 26 October 2005, 18:38 »
I get the following fault codes on the 1.8T mk4 150BHP version.
Engine missfires and got the following codes...
Reads:
17608 (P1200)--Unknow Trouble Code
16684 (P0300) Random Missfire Detected
16688 (P0304) Cylinder 4 missfire
Does this mean i need a new coil pack or something?
Anyone have this trouble before?
chers
Blue
Offline topher
  • Administrator
  • fully functioning
Re: Error codes/ engine missfire !!!!!!!!!!!!!!!!!!!!!!!
« Reply #1 on: 26 October 2005, 18:41 »
what engine code is it ? AGU/ARZ/AUM ?
Offline Mr Blue
« Reply #2 on: 26 October 2005, 18:50 »
AUM :smiley:
Offline topher
  • Administrator
  • fully functioning
« Reply #3 on: 26 October 2005, 19:01 »
aye probably a coilpack then, maybe swap it with one from another cylinder then clear the codes, see if it re-appears on that cylinder ? if not then might be an injector problem.
Offline Mr Blue
« Reply #4 on: 26 October 2005, 22:04 »
nice tip there
chers Topher ill see ''wag1'' tmro :wink:
Offline topher
  • Administrator
  • fully functioning
« Reply #5 on: 27 October 2005, 00:25 »
there was a recall in the U.S, but not in the UK.. an AUM will be out of warranty now but they might make a contribution of you push for it... assuming it is the coilpack failing that is
Offline G7i turbo
« Reply #6 on: 27 October 2005, 10:13 »
I rang VW and they couldn't do my coilpacks on a recall as it was pre 2001, anything after 2001 they will make a good will gesture and replace as they have identified a problem. According to my local VW dealer
Offline Mr Blue
« Reply #7 on: 27 October 2005, 11:29 »
I ended up going to VW and buying a new one. Had to walk it but lucky they are only a few doors down :tongue:
Was the coil in the end and it split in two! Lucky i managed to pull the other half out with pliers or i would have been f**ked  :evil:
Total cost: £28.36p
Thanks for your help people :smiley:
« Last Edit: 27 October 2005, 11:30 by Blue »
