Author Topic: Polo GTI Plus plugs  (Read 3738 times)
Offline silver38
Polo GTI Plus plugs
« on: 15 September 2026, 19:02 »
I have already posted on uk-polos.net.
The plugs and coil packs were removed by the dealer due to a bad misfire. The car has covered 38000miles and is 6 years old, the plugs should have been replaced at 4 years according to the service regime. It's been dealer serviced since new and currently has an all in plan, the plugs and coil packs have been refused as a warranty claim. Do these plugs look like something that has been fitted for 2 years?
Thanks
MKVII GTD Manual - Pure White, 5Door, Adaptive chassis control, Advance telephone connection, Climate comfort windscreen, Discover Nav pro, High beam assist, Keyless entry, Sport and Sound pack, Park assist system with steering assist, Rear view camera, Rear side airbags with rear seatbelt warning, Winter pack, 5 Year Warranty
Offline jv
  • Administrator
Re: Polo GTI Plus plugs
« Reply #1 on: 16 September 2026, 15:08 »
Wow! Has the car been in a lake?!
I'd agree in that they in themselves aren't a warranty claim. More importantly, what has caused it? Old plugs wouldn't normally look like that so it's not just a case of "they are old and weren't replaced 2 years ago". Has someone ever jet-washed the engine? Or any reason for a lot of water to be in the engine bay?
Buy site stuff!
GolfGTI.co.uk - merchandise
Support the forum charity!
Offline silver38
« Reply #2 on: 16 September 2026, 17:15 »
My thoughts exactly when the dealer first sent the photos, never been through anything other than a puddle. Not even been to the sea side.
Thanks
Offline nadab_sardar
« Reply #3 on: 26 September 2026, 09:31 »
If water hasn't got in from outside, the other big cause of corroded/wet-looking plugs is a failed coil pack or a leaking cam cover/rocker gasket letting oil or coolant creep down into the plug wells. If it's a coolant leak into a cylinder that would also explain a rough misfire, and it's worth them checking for a blown head gasket or leaking injector seals too - not just blaming the plugs themselves.
I'd push the dealer for a proper explanation of the actual root cause rather than accepting "plugs are worn so not warranty". If they can't say what let moisture/fluid in there, that's not really a customer-fault issue and worth escalating with VW customer care given it's been dealer serviced under an all-in plan the whole time.
