Author Topic: Gearbox to Upper Mount Bolts - Part Numbers  (Read 873 times)
Offline Bluest
« on: 13 September 2026, 10:35 »
I recently had the gearbox out and my understanding is that the gearbox to engine mount bolts are all stretch bolts and should be replaced. These are the 3 bolts that mount the aluminium bracket to the gearbox and three bolts that connect that bracket to the engine mount. So 6 in total and I think they are all the same.
I bought a gearbox mount bolt kit, but the bolts were mostly wrong as I think those kits are for if you are replacing the actual rubber mount on the chassis leg.
Can anyone confirm the right part number(s) for the bolts I need?
« Last Edit: 14 September 2026, 14:55 by Bluest »
Offline Bluest
Re: Gearbox to Upper Engine Mount Bolts - Part Numbers
« Reply #1 on: 14 September 2026, 10:30 »
Done a bit more digging
The bracket to gearbox bolts are number 22 on the diagram linked below (N10709001), 3 required. I also need 3x number 24, but I don't know the part number or if they are exactly the same as 22. Anyone know?
https://www.akstuning.co.uk/shop/home/3063-genuine-vag-gearbox-mount-bolt-n10709001.html
« Last Edit: 14 September 2026, 10:41 by Bluest »
Offline Bluest
Re: Gearbox to Upper Mount Bolts - Part Numbers
« Reply #2 on: 14 September 2026, 23:01 »
Not wanting to appear to be totally mad by talking to myself, but I think I've solved this.
No.22 on the diagram - N10709001 - M12 × 1.5 × 78 mm - Aluminium bracket to gearbox (3 required)
No. 24 on the diagram - N10552404 - M12 x 1.5 x 70 mm - Aluminium bracket to gearbox mount (3 required)
This is for a manual gearbox, not sure if DSG is the same.
Offline Al1040
« Reply #3 on: 17 September 2026, 14:50 »
Well done for solving your puzzle  :laugh:
Some lucky Mk7 manual gearbox owner in the future will owe you a pint!
67 Plate Mk 7.5 GTD DSG
