Hi all,
I’m looking to upgrade the standard audio system in my 2014 Mk7 GTI and am currently deciding between the VW Helix sound system and JBL BassPro Hub. Both are coming out at roughly the same price supplied and fitted.
The Helix appeals because the subwoofer fits in the spare-wheel well and uses a separate amp to improve the factory speakers. The JBL subwoofer is essentially an all-in-one sub/amp unit and also fits in the spare-wheel well.
I’m leaning towards these rather than Dynaudio as the cost of a Dynaudio setup is more than I want to spend.
My main concern with the Helix is that I understand it has now been discontinued. How much of an issue is that likely to be? If the amp or sub failed in a few years, are replacement parts still reasonably easy to find?
For anyone who has used either system:
- How happy are you with the sound quality?
- Any reliability or installation issues?
- Has anyone had a Helix fail, and was it repairable/replacement parts available?
- If you’ve heard both, which would you choose?
- Is the Helix noticeably better because it also improves the factory speakers?
If you had a Mk7 GTI with the standard audio system and roughly the same budget, which would you go for — Helix or JBL BassPro Hub, and why?
Thanks in advance!
Adz
