Author Topic: Leaving car for 6 weeks  (Read 5056 times)
Offline joe6
« on: 15 July 2026, 10:37 »
I will not be driving the car for about 6 weeks. It will be garaged. I intend to raise the tyre pressures to prevent flat spots. Suggestions what the pressures should are welcome. Is there anything else I need to do? Many thanks.
Offline SRGTD
Re: Leaving car for 6 weeks
« Reply #1 on: 15 July 2026, 11:51 »
Here’s the AI response to your tyre pressure query;
For a Mk7.5 Golf GTI sitting in storage for 6 weeks, inflate all four tyres to 45 PSI (approx. 3.1 bar).Inflating to the upper limits of the tyre's recommended range helps prevent the tyres from developing flat spots caused by the weight of the vehicle resting on the same patch of rubber for an extended period.
It might also be worth putting the battery on trickle charge and as you’re going to be parked in your garage on a level surface, maybe consider disabling the parking brake so the brake pads don’t stick the discs. If you don’t disable the parking brake, ensure the brake pads and discs are dry at the start of the 6 week period to minimise the risk of the pads sticking to the discs.
Gone but not forgotten;
2016 Polo GTI; Blue Silk
Offline joe6
« Reply #2 on: 15 July 2026, 12:59 »
Thanks SRGTD. Useful source of info as usual. Often leave the handbrake off after rain so that also makes sense.
Offline SRGTD
« Reply #3 on: 15 July 2026, 14:53 »
If you do leave the handbrake off, you could also put some chocks in front and behind your car’s wheels as an additional safeguard so it doesn’t roll, although probably not necessary on a level garage floor and with the transmission left in ‘P’ (assuming your car has DSG transmission).
