Author Topic: passenger side mirror  (Read 630 times)
Offline mossy69
  • 2014 Gtd carbon grey pro nav dyn audio keyless wp
« on: 05 July 2026, 16:07 »
hi everyone I'm struggling to set up the reverse passenger dipping  mirror been through the manual and still not working may be its goosed any help appreciated
2021 Gti moonstone grey 19 Adelaide HUD winter pack
2014 GTD carbon grey pro nav dyn audio keyless
Offline SRGTD
Re: passenger side mirror
« Reply #1 on: 05 July 2026, 16:56 »
If you’ve followed the procedure in the manual, it should work.
Which position have you got the mirror adjustment control set to when you reverse? It needs to be set to position ‘L’ on RHD cars (in any VW I’ve owned with dipping mirror function, I’ve kept the mirror adjustment control permanently set in the ‘L’ position unless I need to use the mirror heating function).
After you’ve reversed, the kerbside mirror should return to the non-dipped position when you either a) switch off the engine or b) drive forward and the car reaches a certain speed - I not sure what that speed is but I think it’s something like 10 mph.
Gone but not forgotten;
2016 Polo GTI; Blue Silk
