Author Topic: MkII Glof GTI 1.8 8v.  (Read 1674 times)
Offline Kamanchi Slide
« on: 25 October 2005, 15:17 »
Hello board i'm new to this forum and hope you lot can help me.  I've just taken my car to have it's MOT renewed, and while it was there i asked if they could see why it was overheating.  The guy at the garage said it was overheating cause the headgasket needed replacing or it needed a new head.  The car was overheating after standing still for 10/15 mins and this only happens when it's standing still, when i'm moving i don't get a problem.  I thought it would just be the thermostat as the heaters not working either.  Can anyone advise me if im being ripped off or does this sound like a head gasket or cracked head?  I was under the impression that if the head gasket had gone the oil would go creamy.
Judderi
Re: MkII Glof GTI 1.8 8v.
« Reply #1 on: 25 October 2005, 15:20 »
Does sound suspicious to me. Does the radiator fan kick in? Is the water level ok?
« Reply #2 on: 25 October 2005, 15:22 »
Hello there.  Water level drops after a while and it'll steam from the resevouir but the fan works.
Judderi
« Reply #3 on: 25 October 2005, 15:41 »
You might have a blockage somewhere. If your not confident enought to check or flush the system then take the car somewhere else and get a second opinion.
« Reply #4 on: 25 October 2005, 15:42 »
Thanks for your help.  I'm waiting to hear back from someone as we speak.
Offline Aklass
« Reply #5 on: 25 October 2005, 15:45 »
That does sound dodge :undecided:...  I would go for a thermostat first..  and get the air out the system...   If that doesnt work, then it could be the head. :sad:
Offline Rain
  • forum irregular
« Reply #6 on: 25 October 2005, 15:58 »
faulty thermostat wont stop the heater getting water hot through it  :undecided: if its actually missing it might take longer to heat up but so would the engine and it wouldnt be overheating :S
Offline ...joe
« Reply #7 on: 25 October 2005, 19:31 »
i'd say if you've got steam coming out the cap it'd be worth changing the cap for a new blue coloured one from either vw garage or german and swedish.
the seals go in them and when you un-do the cap it never seats itself properly again. make sure you get a blue one though as they changed the design to improve it and colour coded it.
if that doesn't cure it at worst case its only cost you a few quid.
mail@trimdeluxe.co.uk
www.facebook.com/Trimdeluxe
Offline Organisys
  • Old and Slow...
« Reply #8 on: 25 October 2005, 21:18 »
also, take the cap off, and check coolant is being pumped around by seeing if some is being returned to the header tank via the little hose at the front of the bottle.
 :smiley:
Offline Mk2 Runout edition
« Reply #9 on: 26 October 2005, 14:29 »
Are you sure it's overheating? If you're going by the dial on your instrument panel these can sometimes give faulse readings. Also i would change the temperature sender switch (only cost a couple of quid)
