Golf mk7
Jimble
Coolant swap to G12 Evo - How to drain drain?
Topic: Coolant swap to G12 Evo - How to drain drain? (Read 4435 times)
Bluest
17 May 2026, 19:43 »
I ditched the silica bag today and attempted to swap over to G12 Evo. However, I could only drain about 2.5l from the system and I believe that the capacity is about 8l. So how do I drain it fully to do a proper swap?
Rudedog
Re: Coolant swap to G12 Evo - How to drain drain?
17 May 2026, 21:04 »
Very apt timing as I'm planning to this very soon - I had my heater matrix replaced and although the coolant is clear it's not a bright pink but slightly orange which I've read can happen but I'd rather replace knowing I have the correct mix of G12 Eco.
I've trawled the internet and found this video, which I'm going to probably follow - although I will flush through with de-ionized water before introducing the mix.
https://www.youtube.com/watch?v=wfECBbTP7Tw&list=LL&index=142
Sounds like the trick is to do this on a pre-warmed engine so the thermostat is open plus have the cabin heating on high so all of the old coolant can be removed.
Bluest
18 May 2026, 08:41 »
Thnaks, I'll give that video a watch later. Doing it on a warm engine sounds like a recipe for 3rd degree burns though.
Golf mk7
Jimble
