Author Topic: Rear brake caliper cover (red)  (Read 10213 times)
Offline P6GTD
« on: 24 April 2026, 15:57 »
Bit of an odd question but can anyone tell me if the centre part of the rear caliper should have a cover?
I got my rear discs and pads replaced a few months ago but it suddenly struck me there should be a full centre cover.
See pics below. Any opinion would be great thanks.
Offline P6GTD
Re: Rear brake caliper cover (red)
« Reply #1 on: 24 April 2026, 16:51 »
Or maybe the centre has a grey cover? Pretty sure there should be a cover of some sort.
Has my independent forgotten to fit it back on??
Offline Big Col
« Reply #2 on: 24 April 2026, 17:51 »
look the same as mine
Current - 2019 Golf GTI
Previous, 2016 Golf GTD, 2014 Leon FR, 2010 Ibiza FR, 2006 Fabia vRS , various Vauxhalls
Offline madstaff
« Reply #3 on: 24 April 2026, 18:15 »
Same as mine, it looks like you've still got the anti-squeel shims still fitted too.
Offline P6GTD
« Reply #4 on: 24 April 2026, 18:44 »
OK, thanks for early responders. I have worked out this looks like the back of new pads. I’ve watched a couple of YouTubes now and maybe I’m being a bit “precious”.
I just kind of lost trust in my “VW Independent Specialists”.
It just looked like a space that ought to have had a protective trim ass it had exposed wire clips and an exposed grease face.
Offline willni
« Reply #5 on: 26 April 2026, 10:50 »
It should be a stainless steel cover
Offline P6GTD
« Reply #6 on: 30 April 2026, 17:33 »
Thanks. Yep it is a steel backplate.
The garage had smeared so much grease over it (for an easy re-fit?) that it looked as if there should be some cover but I can see everything is ok.
Just need to clean off the excess grease which is already picking up too much dirt.
