Author Topic: New MK7 owner - Oil leak, help?  (Read 10678 times)
Offline KodapMK7
« on: 15 April 2026, 13:43 »
Hi guys,
Had many a MK5 in my life but recently bought a 2014 MK7 and have to say I am absolutely loving it! However, this morning when I got up to go to work I noticed what looked like a bit of oil on the floor where I had been parked, specifically near the drivers side tyre. I haven't had chance to look at it properly yet or get underneath it, but is there anything 'common' that I should look out for here? Anything on that side of the engine etc that could have caused it?
I have checked the levels manually and it was all good so if it is a leak it's likely to be small.
Offline symonh2000
Re: New MK7 owner - Oil leak, help?
« Reply #1 on: 15 April 2026, 17:55 »
The sump is plastic, it may be worth checking that it isn't cracked. It could also just be spillage from where it has been topped up.
Golf GTI 7 PP
BMW M140i
Offline MinchCS
« Reply #2 on: 15 April 2026, 18:17 »
Mine was the plastic sump as mentioned above. I fitted a genuine VAG steel one in its place.
2017 black Clubsport S
Offline KodapMK7
« Reply #3 on: 17 April 2026, 13:29 »
Thanks guys, will take a nosy this weekend and see what I can see! Does seem to have not lost any fluid the last few days..
Offline Rudedog
« Reply #4 on: 17 April 2026, 13:45 »
Ok might sound silly but are 100% sure it's oil?  I thought behind the front wheel was the classic place for the AC drain to drip water onto the floor.
