Author Topic: 8.5 GTI - issues with fuel system, had the car 4 months  (Read 15895 times)
Offline AbsoluteAnorak
Took delivery of the new car in December. After 500 miles (and 1.5 tanks of fuel) the (yellow) check engine light came on. Reported to local VW dealer in January, and had to wait until Monday this week to get the car seen as they had no courtesy cars available. Picked the car up earlier today after having two new injectors installed, and drove the car home without any check engine light. Glorious.
The glory lasted no more than an hour  :cry: Did the school run at 3pm, started her up only to find the check engine light is on again. Immediately phoned the dealer, who said to bring the car back tomorrow. However ... they have no courtesy cars available until mid-late April. I'm pretty annoyed.
As I had to use the car throughout while waiting for a courtesy car (and VW confirmed the car was fine to drive in the meantime) I added 3000 miles to the car with the check engine light on. I can't say that performance had been noticeably affected, but clearly something isn't right.
Is this a common fault? Anybody else have similar issues? Reading around, others have said that regular visits to VW in the first year of ownership is quite common (and often related to fuel system issues) but I always take Reddit with a pinch of salt. I'm not 100% convinced, given this issue has returned immediately (well, within 20 miles) that this is injector related - although the check engine light did stay off the journey home today, so it doesn't make sense.
Online JoeGTI
Re: 8.5 GTI - issues with fuel system, had the car 4 months
« Reply #1 on: 19 March 2026, 16:31 »
While visits back to the dealer in the warranty period are not uncommon, I must say this "fuel system" issue is a new on one me. I don't recall reading reports of this one before and I've had 2 MK8-generation cars myself and neither have suffered it.
Vast majority of issues people have with these cars are more typically software-related. Reddit (from what I've seen) tends to be more USA-biased too.
Offline Davey-c
« Reply #2 on: 19 March 2026, 20:47 »
I had a Golf R 20 years which had this issue over 14 months of ownership. The car was in and out of VW about 6 times for this issue. They changed or replaced multiple components to try and rectify the issue, sensors, manifold, harnesses and a fuel cap. Absolutely spoiled ownership and I got rid of the car due to frustration. I’ve had plenty of Golfs over the years and this was the first one that ever gave me any hassle. Changed manufacturer and went with Merc in the end due to the worry of getting another Golf and the potential issues reported. Shame as the 20 years was a brilliant car to drive. Hopefully your issue gets resolved and you get to enjoy the car.🤞🏻
2023 Golf R 20 Years, Lapiz Blue, 19 Inch Black Estoril Alloys, Rear Camera, Harmon Kardon Sound System.
Offline Monkeymagik
« Reply #3 on: 28 March 2026, 06:19 »
Sounds like a slightly different issue but mine had a new fuel pump after 6 months because car kept stalling.
2025 GTI, Moonstone, Pano Roof, DCC, 19 inch Queenstown wheels, Towbar, HK Audio, Spare wheel
Gone: 2001 Mk4 8V GTI
« Reply #4 on: 10 April 2026, 16:39 »
Just an update on this, in case it helps anyone else out.
Car has been with the VW dealer in Tamworth for nearly 3 weeks now. Repeated repair attempts appear to not solve the issue. I'm not certain what the extent of their repairs have been so far (other than the initial two new injectors), I was told "wiring needs changing and re-coding" so I assume some harness has been replaced (not sure why that would need coding to the vehicle though).  As of right now, I'm told VW UK technicians have advised to replace the inlet manifold, which is being delivered tomorrow and is being fitted on Monday. We'll see. Will update on any further replacements or progress as and when. What a faff.
I'll be contacting my lease company and the broker v. soon to apply some pressure to VW and enquire about some form of compensation. I'm paying for a GTI and I've been driving a T-Cross for the last three weeks. Pretty big downgrade...
Offline davo245
« Reply #5 on: 12 April 2026, 10:37 »
Sounds like there service dept is a useless as the sales at VW tamworth they were useless when I bought mine would never go back ther tbh
Mk6 GTI DSG
MK7.5 GTI performance DSG
Mk8 GTI
« Reply #6 on: 29 April 2026, 11:06 »
Update: New injector harness fitted. No dice. Master tech took the car home for overnight road test last week, but the fault maintained. Radio silence until today, when I phoned them for an update. Told that a new ECU is now required, as it's "blown" - as they do :whistle: ECU is on backorder, so won't know until Friday when this will be available. Been without the car for 5 weeks now. Fault reported coming close to 5 months ago. I guess I'm just super lucky :cry:
What is a little worrying, is that VW UK are supposedly remotely diagnosing the car at this point, and they clearly don't know what's wrong with it. I suppose it's possible that a component failure in the ECU could be reporting false readings elsewhere in the car, which is why this feels a bit like a trial and error diagnosis. If a new ECU doesn't fix it, then I think I'm just going to ask for a replacement car.
Cannot recommend this experience.
Offline davo245
« Reply #7 on: 16 May 2026, 09:14 »
I would be rejecting this right now tbh they clearly don't know what the issue is and 5 months without a very expensive premium brand car is no way acceptable.
What car have the loaned you?
Mk6 GTI DSG
Mk8 GTI
Offline fredgroves
« Reply #8 on: 25 May 2026, 13:59 »
No vw main dealer is allowed to guess what is wrong.
They use a vw computer system that guides them to troubleshoot and then authorises parts for warranty use.
It's an absolute nightmare when it's anything other than a simple problem.
It's not that their mechanics are stupid or lazy...
I suspect other oem's use something similar too...
Offline davo245
« Reply #9 on: 01 June 2026, 08:10 »
Any updates on this?
Mk6 GTI DSG
Mk8 GTI
