Author Topic: New Head Unit  (Read 32787 times)
Offline KallumLeGrys
New Head Unit
« on: 09 March 2026, 07:22 »
Hi guys i’ve recently just got a MK6 Golf GTI (10 plate).. it has the standard head unit in, I was looking for some advice on what one to get that is decent and has car play on. I have a reversing camera and the dynoaudio system so i’d would like it to work with them too! Any help and advice welcome.. cheers
( sorry if this has been asked lots of times before)
Offline Nino
  • Insta - F6UGA
Re: New Head Unit
« Reply #1 on: 09 March 2026, 07:52 »
It has been asked alot before :)
See here: https://www.golfgtiforum.co.uk/index.php?topic=290235.0
Current - MK6 GTi Edition 35 - Candy White - 3 door.
Offline jdoubleu
Re: New Head Unit
« Reply #2 on: 15 March 2026, 10:46 »
I looked into this. My car also has Dynaudio and reverse camera. From what I could tell, the RCD330 should work fine with Dynaudio but it does not look like a straight swap for the reverse camera. I gave up on my research last time but might revisit in the future!
Offline Nino
  • Insta - F6UGA
Re: New Head Unit
« Reply #3 on: 16 March 2026, 07:28 »
The Dynaudio shouldn't have any special loom for a head unit, all that is taken care of at the amp on under your boot floor with the sub.
With the reverse camera, the RCD330 should form memory have an input via RCA.
Offline jdoubleu
Re: New Head Unit
« Reply #4 on: 17 March 2026, 18:09 »
It does. But stock is RGB I think so not a direct swap. I might have been looking at the wrong advice but it looked quite a lot of work to get the RGB to RCA bits working.
Offline Nino
  • Insta - F6UGA
Re: New Head Unit
« Reply #5 on: 18 March 2026, 07:15 »
Have a watch of this :)
https://youtu.be/7diy5jVYnB0
Offline jdoubleu
Re: New Head Unit
« Reply #6 on: 19 March 2026, 08:30 »
Ah yeah. See they're powering the camera permanently to avoid the complication of making sure it's only powered when in reverse (where I've seen people running cables the reverse lights). I guess it works! Might look into it again then as a summer project...
Ta!
Offline Nino
  • Insta - F6UGA
Re: New Head Unit
« Reply #7 on: 19 March 2026, 09:02 »
Np :)
