Author Topic: What does each ballast do and do they need coding?  (Read 13878 times)
Offline flipflops
« on: 11 February 2026, 20:31 »
Hi, faulty headlight on a mk7 GTI, it was flickering for a while and now dead.
What doe each of the ballasts do please?
Replaced the rear ballast but it's not resolved it.
Do I need to either code the rear one in for it to work, or should it not need coding so replace the front?
If I replace the front one will that need coding?
If it needs coding, will an OBD11 be ok?
Thanks in advance for any replies, MOT in a week so need to sort :)
Offline Watts
Re: What does each ballast do and do they need coding?
« Reply #1 on: 11 February 2026, 20:48 »
Was it not just the bulb then?
Previously:
Offline flipflops
« Reply #2 on: 11 February 2026, 20:51 »
Unfortunately not, swapped both bulbs and no change
Offline rowlers
  • I'm back - MK7 GTI
« Reply #3 on: 13 February 2026, 13:34 »
They don't need coding.
