Author Topic: VW GOLF MK 6 GTI misfiring  (Read 21064 times)
Offline Greenie222
« on: 22 December 2025, 17:30 »
Hi everyone,
   I hope someone can help advise me
I have noticed today that when I put my foot down on the accelerator it’s “lagging” on acceleration and picking up late
Also when it’s stationary and in neutral when I press the throttle it pops at the exhaust?
Has anyone any ideas what this could be and is it an expensive fix?
Kind was tvregards and best wishes for the rest of the year
Mark
Offline Nino
  • Insta - F6UGA
Re: VW GOLF MK 6 GTI misfiring
« Reply #1 on: 23 December 2025, 09:35 »
Hi Mark, welcome
A few things can cause those symptoms on MK6 Golfs, especially the hesitation when accelerating and popping when blipping the throttle in neutral.
Common possibilities include:
Coil pack or spark plug issues – Very common on VW petrol engines. A weak coil or worn plug can cause hesitation under load and popping from unburnt fuel. Usually not expensive.
MAF (mass air flow) sensor – If it’s dirty or failing, the engine won’t fuel correctly, leading to laggy acceleration.
Vacuum leak / split hose – Cracked PCV hoses or vacuum lines can cause delayed throttle response and popping.
Throttle body / carbon build-up – Especially if it’s a petrol engine and hasn’t been cleaned in a while.
DSG-related hesitation (if automatic) – Sometimes feels like engine lag but is actually gearbox response.
First thing I’d recommend is getting the car plugged in for fault codes, even if there’s no engine management light on. That usually points you in the right direction straight away.
It would really help if you could tell us which model MK6 you got?
Most of the above are fairly inexpensive fixes if caught early, so don’t panic just yet.
Current - MK6 GTi Edition 35 - Candy White - 3 door.
Offline Norwichdaz
« Reply #2 on: 23 December 2025, 10:31 »
Sounds like a repeat ish of what u said to me nino lol
Offline Nino
  • Insta - F6UGA
« Reply #3 on: 23 December 2025, 10:37 »
Common issues see :)
Offline Norwichdaz
« Reply #4 on: 23 December 2025, 11:06 »
👍  :laugh: :cool:
Offline Greenie222
« Reply #5 on: 23 December 2025, 16:55 »
Thanks everyone for your helpful comments
Hopefully it will get sorted next week
Have a great Xmas and all the best for the New Year 👍🏻
