Author Topic: Strange heating issues  (Read 10892 times)
Offline Ssharp
« on: 10 December 2025, 19:45 »
Hi all,
I have decided to join the forum to see if I can get any help or recommendations with some strange heating issues going on in my gti. I have a 2013 mk7 gti currently on 88,000 miles, I’ve owned it since August and loved it. However since it has got colder I started to notice the car was giving out lukewarm air at most, even after running for a bit. I checked the header tank and saw there was no silica bag, which made me think the matrix was blocked up. I got the matrix replaced which made no difference. I then moved onto looking at the heater control valve, which when pulled off and I tried to blow through it, it was seized shut. We then replaced that, which was from a breakers yard however the valve didn’t seem faulty and there was no resistance when trying to blow through this one. This made a small improvement however the car is still taking ages to warm up! It’s normally not until I get to work (20 min drive) that any heat comes through whatsoever, but when it comes through it gets very hot very fast. I’m also questioning whether it’s when I slow down or come to a complete stop that the heat starts to come through too, as I have to queue to get into work. I have had the car scanned after the matrix was done and the codes P275300 and P011800 came up, but this was likely due to the coolant being drained, as I’ve had it rescanned and the codes aren’t present anymore. In the past week now, when the heating/ac is completely off, it now appears to be giving out more heat when it is actually on (I don’t know how!). My only thought was that it may be a coolant temp sensor as it seems to get up to temp pretty quickly and doesn’t really fluctuate from 90 even when being driven hard. It’s also worth noting the water pump hasn’t been replaced yet and there is very very minor residue around it. Other than that I am stumped. I appreciate that this is a very long post however I figured this would be the best place to come for help, therefore any is really really appreciated.
Cheers,
Sam
Offline Pkempster
Re: Strange heating issues
« Reply #1 on: 10 December 2025, 21:04 »
Hi, sorry I’m not able to give any solutions but I am facing the same kind of issues with my 2019 GTI. As soon as the weather got around single figures I noticed it takes ages to start to produce warm air inside, the windscreen is slow to demist and even after 20 minutes it’s only giving out luke warm air. I turn the temp up to 26, 28, HI but it doesn’t blow out that hot.
It’s booked into VW next Tuesday for them to do a diagnostic. I have an all-in service plan and warranty but have read of people being refused certain fixes on that. I have been suspecting the heater matrix or heater support pump based on reading others with similar problems.
I will post next week once they’ve done some checks.
Offline 2007GTI
« Reply #2 on: 11 December 2025, 08:57 »
Ive been round in circles with my car with same issues and it was a blocked heater matrix, no fault codes to say it was.
It is possible to do it yourself, there are obviously videos, but I am not confident on the flushing the system etc, and I am lucky to have a trusty local mechanic who isn't vat registered, so I paid £500 labour, then £61 for pattern new matrix from GSF and £25 for genuine clamps and O rings from stealer. I am usually a fan of using OEM parts, but mine was Denso type and not cheap, plus it's not a complicated part.
I was quoted £900 by well known VW indy 1 year ago, as personally I wouldn't go near a stealer for this type of job, they might get an apprentice to do it and f**k it up. Plus book rate is 6.8 hours at I'm guessing £80 per hour plus vat (someone please correct me if more or less), plus dealer expensive parts, could be £1000+.
My thread here:
https://www.golfgtiforum.co.uk/index.php?topic=291392.0
« Last Edit: 11 December 2025, 09:01 by 2007GTI »
Offline Finglonga
« Reply #3 on: 13 December 2025, 11:12 »
When you turn off the engine after a drive can you hear the Aux heater pump carry on running? It will is not loud but a hum after the engine stops and carries on for a few minutes to cool the turbo. If it has failed it restricts the flow and could be your issue.
The main water pump will still work as it is mechanical run from a belt and if that fails you will overheat quickly.
Offline 2007GTI
« Reply #4 on: 13 December 2025, 21:00 »
Fun fact, my aux heater was also faulty, that was replaced a year ago!
« Last Edit: 14 December 2025, 21:58 by 2007GTI »
Offline Ssharp
« Reply #5 on: 14 December 2025, 16:38 »
Hi mate, yes I can hear the aux pump running afterwards, thanks for the help though.
