Author Topic: 1.8/2ltrTurbo conversion  (Read 4295 times)
Offline mk1mat
  • MK1 1800 Gti
« on: 29 October 2003, 16:39 »
Anyone got any ideas exactly what is involved in putting a 1.8/2ltr turbo in a mark one golf, i.e. wiring loom, engine mounts and strengthening the structure.  Thanx
Offline mk1
Re:1.8/2ltrTurbo conversion
« Reply #1 on: 29 October 2003, 23:06 »
8 valve or 16 valve engine, what fuel system do you want to run, what sort of power do you want. Will you do the work yourself?. It is a lot of work  ;).
Steve.
Offline mk1mat
  • MK1 1800 Gti
« Reply #2 on: 05 November 2003, 16:15 »
ideally would like 200bhp+ was thinking of the new vw/audi engine mate works there and says theres alot of power available from this unit, would be doing work on car with a mate and his old man, so we should be able to get there in the end!!!! need as much info as possible as i just love mk 1's there the best!!!
Offline mk1
« Reply #3 on: 05 November 2003, 20:55 »
Quote  " Anyone got any ideas exactly what is involved in putting a 1.8/2ltr turbo in a mark one golf, i.e. wiring loom, engine mounts and strengthening the structure."
What 2ltr turbo engine is this?.
I have a 2ltr 16v engine in my mk1,and it has a turbo on it. The 1.8 turbo should fit without to many probs, as long as you use just about the whole donor cars wiring loom and the ECU. Or you could go "stand alone" for the engine management.
Engine should mount up ok, if you use the "o2a" box you will have to modify the mounts or buy a kit, cut holes in the bulk head to run the shift cables and "mix and match" the drive shafts to whatever hubs you will use. Don't take this the wrong way, make sure that you understand what is involved before you undertake a project like this. ;)
 Good luck, keep us involved-informed and if you need more info or advice, I'm sure the "gti crew" will help.
Steve.
Dinky
« Reply #4 on: 07 November 2003, 21:32 »
Mk1,
Not being geet nosey or nowt but how much did it cost u approx for ur conversion?If u don't mind us asking?
Dinky :-*
Offline mk1mat
  • MK1 1800 Gti
« Reply #5 on: 07 November 2003, 21:52 »
After a bit more consideration i think it would be more suitable to use a 1.8T but do you have any suggestions for a donor car, is the engine in a vw the same as an audi or skoda? what sort of structural strengthening is needed? seam weld the chassis? still very interested, thanks for advice steve, one other question is how does it go? or need i ask!!!!!
Offline blakheet
« Reply #6 on: 07 November 2003, 22:09 »
i wouldn't seam weld the chassis, but please don't regard anything i say as gospel, i only looked at doing this conversion and gathered all the info, a person who has actualy done it will be a far more reliable source.
i've heard bad things about seam welding chassis', in crashes they are too stiff, try this out, should give you some info.
http://www.performancevwmag.com/forum/topic.asp?TOPIC_ID=17959
http://18tproject.stealthracing.co.uk/ for a mk3
http://www.performancevwmag.com/forum/topic.asp?TOPIC_ID=19038
http://www.performancevwmag.com/forum/topic.asp?TOPIC_ID=18326
http://www.performancevwmag.com/forum/topic.asp?TOPIC_ID=17676&whichpage=2
picture by picture into a mk3
http://forums.vwvortex.com/zerothread?id=896084
indepth post again into a mk2, but the differences are only subtle
http://forums.vwvortex.com/zerothread?id=808137
and for the mk1
http://www.gtiworld.fsnet.co.uk/
(took these from a v. helpful post in performance vw mag, before anyone accuses me of plagiarism
that last url is damn good, basically a step by step for the whole thing. gd luck if you decide to go ahead.
« Last Edit: 07 November 2003, 22:21 by blakheet »
Offline mk1
« Reply #7 on: 08 November 2003, 09:16 »
It goes very well  ;D, don,t have any HP figures yet but it is booked in for a rolling road session on the last wednesday of the month. Lots of different 20v engines, so do your research, late mk2 would be the simplest conversion due to the central electric fuse box. I didn't weld the chassis, I don't anticipate any problems as long as your shell is in good order (people put vr6 engines in mk2s without any strengtening). I would love to do the 20 valve conversion, but didn't find a donor car for fair money, good luck. Steve.
Good links blakheet.
