Author Topic: Ride Height comparison  (Read 4838 times)
Offline CrunchtheApple78
« on: 25 November 2025, 15:07 »
I have tried to find out a ride height comparison between my 7.5PP with DCC and the ED50. So far I’ve got the following
Standard golf - 136mm
7.5 performance - 20mm lower
DCC - additional 5mm lower
Making 111mm
Standard - 136mm
ED50 - 15mm lower
Perf Pack - additional 5mm
Making 116mm
None of what I have found fills me with confidence on accuracy. Can anyone help with correcting or confirming the above please?
Also, what is clubsport ride height as a comparison to both my 7.5 and ED50?
Thanks.
Offline DrG_GTi
Re: Ride Height comparison
« Reply #1 on: 26 November 2025, 10:38 »
As i understood it, DCC actually raises the car +5mm - believe this was also true on the 7.5s too
From a while back:
Golf 8 ride heights <trim levels>:
Base/Life/Style = 0mm
R-Line = -15mm
GTI/GTD = -15mm
R = -20mm
GTE = +25mm
DCC equipped = -10mm instead of whatever stated above.
So to be clear on that the common answer was, yes DCC cars sit higher than non-DCC cars.
2021 Mk8 GTI Clubsport - Reflex Silver
