Author Topic: Washer Pump - QA time  (Read 7203 times)
Offline HonkeyGonk
« on: 17 November 2025, 12:32 »
Hi all,
As soon as I spoke on another thread about having no issues, I get 2 in the space of 2 weeks!
This time its the rear washer not working on the 19' plate GTi I have.
No washer fluid is reaching the rear nozzle (tested by disconnecting the rear nozzle in the spoiler which was fun) and tried the pump - not even a drip. Tried manually blowing/creating suction on that pipe in case it was a blockage close by, no luck.
I can hear the pump going and the fronts work just fine. I also can't see any obvious signs of a broken pipe as no washer fluid is appearing anywhere - not inside or outside.
I've been googling replacement pumps but I'm not sure if it's at fault? I read that its the same outlet and the polarity changes, so the rear washer not working isn't indicative of a failing pump?
Is there anything else I can do to check issues (or where to check) before I change the pump and see what happens?
Thanks in advance!
Offline Redreels
Re: Washer Pump - QA time
« Reply #1 on: 17 November 2025, 19:05 »
If the pump operates when using the stalk it sounds like a blockage. You really need to access the washer bottle and check. I assume there will be two pumps ( f&R) if they both whir when being operated it will be a blockage. Generally if a hose has come off you will get the water being dumped elsewhere
Offline HonkeyGonk
« Reply #2 on: 17 November 2025, 20:10 »
I'm not sure there are two pumps, I thought there was only one? Anyone with a UK 7.5 able to confirm?
I'm hoping if it's a blockage, it's right by the pump coz there's no way I'm getting it out of its not.
Offline Redreels
« Reply #3 on: 19 November 2025, 20:19 »
I would suggest accessing the bottle anyway, you will have to disconnect the pipe to clear a blockage.
