Author Topic: AC leak...  (Read 26077 times)
Offline rowlers
  • I'm back - MK7 GTI
AC leak...
« on: 10 November 2025, 15:31 »
Has the Golf down to get a the AC checked and it has a slight leak. Unfortunately they are unable to pin point where it is...
So now I'm a bit stumped (and gutted). What do I do now? Any advice?
Offline Redreels
Re: AC leak...
« Reply #1 on: 10 November 2025, 19:24 »
They should add a dye to the gas which will allow them to detect the leak with a UV light. Pretty basic AC stuff.
If they are working on you AC and do t have e this basic equipment, please find somewhere else
Offline Adam T7
Re: AC leak...
« Reply #2 on: 10 November 2025, 20:13 »
Bang on, I had an a/c leak in a brand new Discovery over 20 years ago, took the dealer about 30 mins to find the leak.
Offline jdoubleu
Re: AC leak...
« Reply #3 on: 11 November 2025, 13:41 »
The oil that is in the system as standard should pick up under UV light. Certainly when I had a leak, it was fairly obvious where it was coming from in a dark garage under a UV torch. Didn't need any specialist die to be added.
The only difficulty might be that some of the pipes go behind the firewall and then I assume you'd need some sort of camera that can feed behind the dash. Definitely start with under the bonnet though- that's where pipes, condenser, seals etc have to deal with the elements and stones being kicked up driving.
Offline rowlers
Re: AC leak...
« Reply #4 on: 11 November 2025, 19:58 »
They have done all this, the dye is not showing up anywhere that was visible. It held pressure, and held a nitrogen vacuum test, hence the difficulty in identifying a leak...
Offline Redreels
Re: AC leak...
« Reply #5 on: 11 November 2025, 22:21 »
So it isn’t leaking then if it’s holding pressure?
What is the actual fault you have?
Offline MinchCS
Re: AC leak...
« Reply #6 on: 12 November 2025, 08:36 »
They can hold vacuum and still have a slow leak. Been there - a few times :(
2017 black Clubsport S
Offline rowlers
Re: AC leak...
« Reply #7 on: 12 November 2025, 11:34 »
It looses gas/cooling after ~12months. So asked them to identify the leak so I could fix it.. But they can't identify where the leak is..It must be tiny...
I guessed I'm just going to have to regas again and see.how it goes...
Offline Redreels
Re: AC leak...
« Reply #8 on: 12 November 2025, 18:00 »
It could be natural seepage in that case. Try and use the AC more frequently to help lubricate the system. I wouldn’t be overly worried over a 12 month period
Offline rowlers
Re: AC leak...
« Reply #9 on: 13 November 2025, 16:19 »
Thanks.
They guys at the garage, did say that the new gas (r1234yf) is really bad for general "leakage", much much worse than the older r123 gas.
I generally leave the AC on 247, maybe I've just used it up lol
