Author Topic: acceleration hesitation  (Read 15866 times)
Offline greencode
  • Golf R - Pure White
« on: 02 October 2025, 10:09 »
Tricky one to explain but when changing gear there's sometimes a bit of hesitation to accelerate quickly and smoothly. It feels like it slows down a little and then quickly speeds up to normal acceleration (no idea whether I've explained this very well!!!)
It's as though there's a slight lag before accelerating smoothly.
It's a 2017 Golf R that I've owned since new and serviced every year. It's done 41,000 miles.
Any ideas?
« Last Edit: 02 October 2025, 10:22 by greencode »
Offline Beebopper
Re: acceleration hesitation
« Reply #1 on: 02 October 2025, 12:29 »
Could be a sensor perhaps, have you had it scanned for any logged faults? Sometimes minor one's don't flag up an engine check light. Also, have you ever had the plugs changed, could be related if they are still original. First check for faults I'd say, to avoid chucking money at chasing an issue.
Prior - MK2 GTi Big Bumper in White
Current - MK8 GTi Clubsport in Moonstone Grey
(Plus Many other non-Golf hot-hatches in-between!)
Offline greencode
« Reply #2 on: 02 October 2025, 13:34 »
Thanks for this. Just looking back, the spark plugs were changed at 30,000 miles (March '23). I don't have a fault reader but may just buy one and check that. Beyond that is there anything else to check?
Offline Beebopper
« Reply #3 on: 03 October 2025, 12:25 »
I think if plugs were done, get it read for faults, hopefully something in the memory that gives a pointer.
Offline greencode
« Reply #4 on: 28 December 2025, 19:23 »
I ran the scanner and nothing came up. I gave it a good drive today and hard accelerated through the gears. It’s strange. When I accelerate it’s as though it’s not a smooth pull. Not sure if this is called a flat spot. It feels like the car is "catching its breath" or hitting an invisible wall before it remembers and starts pulling again.
Any ideas?
« Last Edit: 28 December 2025, 19:29 by greencode »
Offline wez68
« Reply #5 on: 01 January 2026, 12:31 »
Hi ,I had a similar issue with my GTI PP very recently and my car also felt a little flat in general ,I had a feeling it was the diverter valve ,I bit the bullet and bought one from TPS and fit it yesterday ,car is flying now and it's cured all my issues ,the one I took of was a revision C the new one is a revision J ,might be worth replacing yours .
Offline greencode
« Reply #6 on: 04 January 2026, 14:44 »
It seemed to do something different today. When accelerating it seemed to over rev before coming back down to normal revs/acceleration. Not a loud over rev but more noticeable when looking at the rev counter.
Offline MinchCS
« Reply #7 on: 04 January 2026, 15:56 »
That sounds like the clutch..
2017 black Clubsport S
Offline greencode
« Reply #8 on: 09 January 2026, 16:22 »
Two estimates, so far, for the clutch and flywheel. OEM which is Sach. £1300 and £1600!
