Author Topic: Audi 19" rotors  (Read 8393 times)
Offline petec
Audi 19" rotors
« on: 28 August 2025, 19:55 »
Sorry, tried searching but drew a blank, any idea which 19" Audi rotors fit a MK7.5 GTi, seen at least one set fitted but want to be sure I buy the right ones. Thanks
Re: Audi 19" rotors
« Reply #1 on: 01 September 2025, 22:32 »
Avoid anything originally designed for an A1 as the PCD will be all wrong (5x100 not the required 5x112)
I used to know all the specs but can’t remember a lot of it now so I’ll have to be vague.
The bigger Audis use a bigger hub, you need a 57.1 centre bore but wheels for the A6’s and the like have much bigger centre bores which would need sleeving down with spigot rings.
If you stick with 8” wide versions you can get away with around 40mm offset on the front and 35mm on the rear of a 7.5 Golf.
Go wider than 8” and you’ll have to be careful with catching, particularly on the front.
Offline petec
Re: Audi 19" rotors
« Reply #2 on: 04 September 2025, 19:21 »
Thanks, pretty much what I needed to know..
