Author Topic: Creaking door cards  (Read 3645 times)
Offline Tarmac_Terrorist
Creaking door cards
« on: 19 August 2025, 22:00 »
Really pleased with my 8.5 which I bought in March. One concern I have is that when moving slowly 5-10mph over uneven cambers or surfaces, I hear creaking from all the doors and it sounds as if the chassis is flexing / body very slightly twisting. I have the pano roof and I wondered if this makes the body shell slightly less rigid?
Offline SRGTD
Re: Creaking door cards
« Reply #1 on: 19 August 2025, 23:02 »
It’s likely that the door seals have dried out and they’re moving / rubbing against the bodywork when the car body flexes (slight flexing of the body is normal). Some car cleaning products can cause the door seals to dry out and some waxes / sealants can also make the seals squeak and creak. I think that 3 or 4 of the five VW’s I’ve owned have suffered from the creaking noise you’ve described (none of them had a sun roof).
Applying a lubricant such as VW’s Krytox, Gummi Pflege or similar product to the door seals usually cures it. Krytox is quite expensive for a small bottle but a little goes a long way. With Gummi Pflege you get a much larger quantity for much less £’s but it’ll likely need to be reapplied more frequently than Krytox.
Gone but not forgotten;
2016 Polo GTI; Blue Silk
Offline Carlosfandango
« Reply #2 on: 20 August 2025, 07:55 »
In my experience, the creaking you describe usually comes from the door seals, in particular the flocked furry part that runs along the top of the doors. Having tried many products on many GTI’s over the years, the only thing that I’ve found to deal with that area specifically is Normfest dry lubricant spray, https://ebay.us/m/RE4t7A
As mentioned above, Krytox etc are very good for all the other seals, I found that they didn’t apply very well on the ‘furry’ seal though, and were a bit messy in that area because of it, I have had good results with the dry lubricant in the link. What ever you use it will need re applying periodically.
Current -
Gone -
2022 Mk8 GTI DSG, Kings Red.
2003 Mk4 R32, Reflex Silver.
1991 AX GT.
1984 Mk1 XR2.
Plus many more.
« Reply #3 on: 23 August 2025, 18:10 »
Thanks for the suggestions. Dry weather probably not helped
