Author Topic: 18” Queenstowns  (Read 16711 times)
Offline P6GTD
18” Queenstowns
« on: 11 August 2025, 20:10 »
On today!
2kg lighter per wheel than Parkers and they sit out a bit too.
Thanks to Liam at CM Wherls for waiving the £30 carriage when I mentioned this forum.
I’m very pleased with the change in appearance.
I will thoroughly clean and store the Parker’s for the day I sell (if I ever do!)
Offline P6GTD
Re: 18” Queenstowns
« Reply #1 on: 11 August 2025, 20:13 »
Offline david25
Re: 18” Queenstowns
« Reply #2 on: 12 August 2025, 07:36 »
They look like the old Monza wheels from the MK6 and suit the grey very well
« Last Edit: 12 August 2025, 08:29 by david25 »
Now = 2011 MK6 GTI - Reflex Silver
Past = 2006 MK5 GTI - Tornado Red and Solid Black
Offline P6GTD
Re: 18” Queenstowns
« Reply #3 on: 12 August 2025, 08:16 »
Thanks for that.
My pal got an 8.5 with the 19” Queenstowns in January and I was very taken.
Then I spotted this on Reddit. Someone (in US) had photoshopped the wheels onto a grey 7.5.
And the itch had to be scratched……
Offline SRGTD
Re: 18” Queenstowns
« Reply #4 on: 12 August 2025, 08:55 »
I think they also suit the mk7.5; probably because the side profile of the mk7.5 isn’t that much different to the mk8.5.
@P6GTD;
  • be sure not to get too close to pavement kerbstones; from your last picture, your tyres don’t look as if they provide too much rim protection against kerb rash.
  • my car OCD would force me to line up the bottom of VW emblem on the centre caps with the valve stems; like on the photoshopped picture of the US Golf you posted :grin:. If you do decide to realign them, be sure to push them out from the reverse side to avoid damage to either alloys or centre caps. Alternatively, use one of those suction cup puller tools that you attach to the front of the centre caps :smiley:.
Gone but not forgotten;
2016 Polo GTI; Blue Silk
Re: 18” Queenstowns
« Reply #5 on: 12 August 2025, 14:44 »
I’m impressed. They look surprisingly good on the 7.5 and realy do suit the colour scheme very well.  :cool:
Offline P6GTD
Re: 18” Queenstowns
« Reply #6 on: 12 August 2025, 18:24 »
SRGTD : thanks for tips.
I put on new Firestones as I always found the rim protection among the best but I see what you mean.
I went with 225 as I always wanted the ease of dropping back to my original alloys at any time. I think 235 on 7.5J would not be good.
The original alloys are 7.5J while Queenstown are 8.0J which means that while within the safe recommended range, the new combo is a wee bit stretched.
I got the Firestones at £380 all in for 4 on a Blackcircles offer. As it would have cost me £80 to swop the existing tyres (3mm), I figured I would just go all in so hopefully no tyre fitting “jemmys” on the Queenstowns for a couple of years.
I have never replaced original alloys before so this took a lot of agonising. Always wanted to stay at 18” though. I looked at Racingline Evo, OZ Leggera Grigio and versions of 18 Prets.
I like my new alloys as they are a nod to the new 8.5 and therefore have VW “vibe” about them.
The centre caps with red ring are TCR from one of the optional alloy choices (Belvedere maybe?) The red flash just catches the eye against the calipers.
Offline P6GTD
Re: 18” Queenstowns
« Reply #7 on: 12 August 2025, 19:17 »
PS : the tyre/rim situation might be a slight optical illusion because the face of the Parkers was tight against the tyre edge but the new wheels have a groove running in around the meeting of the alloy and the rubber.
Anyway, that’s my hope! :rolleyes:
Offline GTIreland
Re: 18” Queenstowns
« Reply #8 on: 13 August 2025, 02:56 »
I'm also running 225 on 8J rims, good to see I'm not alone. 235 is slightly too off-roady looking for me.
2016 Mk7 GTI PP CSG Manual
Offline P6GTD
Re: 18” Queenstowns
« Reply #9 on: 19 August 2025, 20:15 »
Damn you SRGTD!
I’ve now taken the centre caps off and lined them up with the valves.
What kind of pervert are you???
Wheels are getting a few comments with the words Alfa Romeo featuring.  :grin: :grin: :grin:
