Author Topic: Intake manifold  (Read 26114 times)
Offline joe6
Intake manifold
« on: 31 July 2025, 15:43 »
Second manifold to replace!! First replacement was an updated version after 4 years so suppose this one has lasted better after a further 11 years. Might leave it for a bit as don't do many miles
Offline Snoopy
  • Moderator
  • Geoff.
Re: Intake manifold
« Reply #1 on: 31 July 2025, 21:53 »
Has it failed exactly the same way?
Current Garage:
35+ years of GTI ownership.
Offline joe6
Re: Intake manifold
« Reply #2 on: 01 August 2025, 09:39 »
Same fault code and engine management light. Not had a chance to check yet but likely that flaps are not moving correctly. Is not affecting driving at the moment. Surprised if it is carbon build up as have been using 99 Octane for last 12 years.
Offline joe6
Re: Intake manifold
« Reply #3 on: 02 August 2025, 11:10 »
Reset the fault using VCDS and now driven nearly 100 miles with no recurrence. Maybe just a blip :huh:
Offline Snoopy
  • Moderator
  • Geoff.
Re: Intake manifold
« Reply #4 on: 02 August 2025, 18:52 »
Depends what milage done on that time I suspect. Maybe starting ro get coaked up restricting movement slightly at the moment. If happens again maybe remove and clean.
Current Garage:
Offline davo245
Re: Intake manifold
« Reply #5 on: 07 August 2025, 16:20 »
Mine did this years ago RAC reset it came back after a few weeks as flap sticking on the in let manifold.
New manifold fitted under extended vw warranty was fine then.
It will definitely go again unfortunately.
Mk6 GTI DSG
MK7.5 GTI performance DSG
Mk8 GTI
Offline joe6
Re: Intake manifold
« Reply #6 on: 29 March 2026, 17:18 »
Revisiting this thread. Took manifold off and cleaned which seemed to work as carbon build up. Lasted for about 3 months then fault back so have now replaced it. What a pain to keep removing and then got a misfire and smoke after new  manifold installed!! Tested spark plug and coil but it eventually found I must have damaged an Injector on cylinder 4 so removed again. Finally all fixed. May be time to sell?
