Author Topic: Error in the emergency SOS system?  (Read 3488 times)
Offline nuoptik
« on: 11 July 2025, 17:55 »
Hi Peeps, I have a 2019 7.5 <cough> R  :whistle: Estate/Wagon that's recently started throwing errors in the emergency alert system - something i've never used or thought could be used without paying for the VW connect service (that i no longer do).
The car says this through the speakers, quite loudly, and the light next to the SOS button turns red. It does it seemingly randomly, and then goes back to functioning, and green light, and then does it again. Its loud and kinda off-putting when it happens.
The only thing that it may or may not be related to was using a roof rack for the first time last weekend and a cable getting snagged on the antenna on the roof while loading or unloading from the roof rack. It's not been visibly damaged, moved, or loosened, but it's the only thing that coincided with this alert starting.
Do we think it's related, or just a red herring? I've found some posts from a few years back of the system being replaced under warranty when other R's similarly threw SOS errors, but my car is alas no longer under warranty, and i don't want this to cost me a ton from VW, for something I don't even use.
I have an OBD11 dongle, could i use this to silence or turn off the SOS system potentially?
I thought about pulling down the headliner to look at the gps antenna to see if something had been knocked loose, but i don't even know if this has anything to do with the SOS alert system, and I'm not super brave about messing with the headliner. Don't want to make anything worse.
Any confirmations or help would be appreciated.
Offline Redreels
Re: Error in the emergency SOS system?
« Reply #1 on: 11 July 2025, 20:42 »
I would certainly believe they are linked. How on earth did you manage to snag it?
