Author Topic: Aircon drainage  (Read 5914 times)
Offline lee3011
Aircon drainage
« on: 13 May 2025, 17:40 »
Currently got a 2019 GTI PP covered only 35k, just recently I’ve noticed that when using the aircon there doesn’t seem to be anything from the drain hole underneath the car, I’ve checked the drainage pipe in the car under the carpet and it all looks good and bone dry everywhere no leaks at all and no bad smells, the pollen filter was replaced last November at its service with vw, not sure if I’m just being paranoid
Online Adam T7
Re: Aircon drainage
« Reply #1 on: 13 May 2025, 18:09 »
Possibly due to the very dry weather, humidity %’s are very low compared to normal. If the Aircon works and carpets dry, not sure what else to suggest?
Offline lee3011
Re: Aircon drainage
« Reply #2 on: 13 May 2025, 18:31 »
yeh the aircon is ice cold and as I said the carpet and surrounding area is bone dry..
Offline Finglonga
Re: Aircon drainage
« Reply #3 on: 15 May 2025, 20:24 »
As said the weather is dry, had mine on max and nothing under the car same on the BMW.
Offline Finglonga
Re: Aircon drainage
« Reply #4 on: 13 June 2025, 23:17 »
Had some visible drips under mine today, first time since this thread was started.
