Author Topic: AC pressure switch  (Read 25677 times)
Offline Pillharrier
AC pressure switch
« on: 18 April 2025, 08:51 »
Hi
So I need to change the AC high pressure switch which has a fault code and is possibly the cause of a fan issue.
It's a 1.8t GTi AGU engine. I can identify one pressure switch bottom left behind the fans in front of the compressor. Is this the high pressure switch?
Anyone know if there's a low pressure switch also and where it might be located? Thanks
