Author Topic: Harmonic Damper  (Read 3203 times)
Offline RICH 789
Harmonic Damper
« on: 19 March 2025, 19:15 »
Does anyone know where I can obtain the Harmonic Damper that Audi used to  fit to an A3 Chassis
Apparently it also fits to a 7.5 GTI.
I have an awful hollow droning noise on my GTI. New rears fitted and wheel bearings seem to be fine.
I have read that this damper can help, but some people seem to have to order from abroad.
Offline Watts
Re: Harmonic Damper
« Reply #1 on: 19 March 2025, 20:05 »
I've one fitted to mine and it definitely makes a difference. Can't say if it will resolve your particular issue. Is it a new noise or from day 1? It could still be your tyres.
Link to part numbers and fitting guide. Just order from an Audi dealer.
http://www.vwgolfmk7problems.uk/contents/en-uk/d5_Rear_Subframe_Damper.html
Previously:
Offline Finglonga
Re: Harmonic Damper
« Reply #2 on: 19 March 2025, 21:33 »
I also have one fitted to my MK7 made a big difference to road noise in the cabin. Seems a decent price from below. You will need the nuts and washers as well.
https://www.lllparts.co.uk/product/1k0505563/volkswagen-1k0505563-balance-weight
Offline niceguy235
  • 2019 GTi PP
Re: Harmonic Damper
« Reply #3 on: 20 March 2025, 07:36 »
Quite an interesting topic as i seem to have the same problem, although i think it could be down to the rear tyres as they are the original Pzeros fitted from new which have covered 55k.
I asm going to get those replaced first and see if that improves the noise.
I also just had a quick feel and i appear to have the two holes for the mounting but the exhaust goes right underneath the recess so access could be a bit tight to fit it!
