Author Topic: warning lamps  (Read 16776 times)
Offline korky
warning lamps
« on: 17 February 2025, 13:51 »
On my 2015 GTD, when you turn on the ignition only 3 lamps illuminate, seat belt, traction control and put foot on brake pedal, these all work as they should, there are no fault codes on engine, abs etc 9 checked with vcds.
I did buy the car with several faults last year but these have all been fixed and I can't remember if they have ever worked, the issue only came to light when it failed mot for no abs lamp.
One other thing, ever since I bought the car it has had a warning message 'instrument cluster workshop'
Everything on the car works perfectly
Any ideas?
