Author Topic: Creaking sunroof  (Read 6773 times)
Offline Deddi
  • 2016 GTi 3 door DSG
Creaking sunroof
« on: 12 February 2025, 21:22 »
My creaking sunroof is really starting to bug me now. I have done a lot of research and have seen a sunroof service post which looks a good idea.
I have gumni pledged the rubber and cleaned up everywhere around the sunroof which has not worked.
I am just wondering if anyone on here has found a way of stopping the creaking that has actually worked?
Thanks
2016 White GTi DSG 3 door
Offline Watts
Re: Creaking sunroof
« Reply #1 on: 12 February 2025, 21:36 »
Are you 100% sure it is the sunroof? Lubricating the seals is the only way I know of. I assume you have driven with it open to confirm it's not door seals as they need lubricating too.
Previously:
Offline Adam T7
« Reply #2 on: 12 February 2025, 21:45 »
Cars have an annoying habit of hiding where creaks actually come from. I’m with Watts - from personal experience, clean and Gummi Pflege the door seals and see how you get on.
Offline willni
« Reply #3 on: 13 February 2025, 20:06 »
As above I had an annoying creaking from my sunroof, it turned out it was the rear seat latches.
Offline Deddi
« Reply #4 on: 13 February 2025, 20:35 »
Thanks for all the suggestions. I'll have a good look around this weekend and see if anything is obvious.
Offline Goat_on_a_bike
« Reply #5 on: 17 February 2025, 08:54 »
I’ve got the same, bit of a weird noise above/behind my driving position. Almost like it’s something rattling. The amount of times I’ve checked the rear seats are clicked in place!
How’d you discover it was the rear seat latches? Mine’s a 5 door and still under new car warranty (in Australia) until September 2025, thinking of taking it in. I got it last month and only done 16k miles.
Offline Watts
« Reply #6 on: 17 February 2025, 10:02 »
I had an annoying rattle coming from the rear left for months which I though was the parcel shelf. But a lucky find was that the little plastic covers on the top of the front passenger seat that the head rest bars passed through were loose! They just need a twist to secure them and problem solved. Couldn't quite believe how much noise a small bit of plastic could make.
Previously:
Offline SRGTD
« Reply #7 on: 17 February 2025, 10:36 »
I’d be loathe to let a dealer try and find an unwanted interior cabin noise; I’ve read ‘horror stories’ on forums of dealers damaging pieces of interior trim (and then denying causing the damage) when removing the trim to try and locate unwanted cabin noises, plus creating more unwanted noises by not refitting the trim correctly / securely.
If you flip the rear seat backrest forward and the rattling noise stops, it’ll almost certainly be the rear seat latches that’s the source of the unwanted noise. The quick and easy DIY fix is to wrap some tape (electrical insulation tape or similar) around the metal loop that the seat backrest catches latch onto which removes any free play between the catches and the metal loop and should stop the noise.
Gone but not forgotten;
2016 Polo GTI; Blue Silk
Offline Adam T7
« Reply #8 on: 17 February 2025, 10:57 »
Totally agree on not going down the dealer route. My ‘rattle’ actually turned out to be the door seals chattering against the painted door frame - probably due to my over zealous use of wash & wax shampoo coating the rubber. Cleaned seals and frames with isopropyl and treated the rubber with Gummi pfledge - seems to have worked ok. Absolutley drove me to distraction though.
Offline willni
« Reply #9 on: 17 February 2025, 13:54 »
As SRGTD's recommendation, just tesa / fabric tape around the rear seat latch hooks. VW actually discovered it for me, after I had mentioned it to them during a service.
