Author Topic: Seized bonnet latch  (Read 3229 times)
Offline SuperScaff
Seized bonnet latch
« on: 11 January 2025, 23:43 »
Had to unbolt the latch today to gain access as the handle has stopped working due to the mechanism getting a little rusty and seizing up also noticed the cable wasn’t seated properly in the unit
Cleaned it up well and applied plenty of lithium grease now it’s a slick as glass to open and close
Offline SRGTD
Re: Seized bonnet latch
« Reply #1 on: 12 January 2025, 08:09 »
It might also be worth doing the zip tie modification around the bonnet release cable junction box as a fairly common issue is the ‘ball and socket’ joint inside the junction box failing, which then prevents the bonnet being opened.
Check out the discussion topic over on golfmk7.com forum at the link below (the first post) which includes a picture of the modification. The diagram in the first post is of a LHD car, so the junction box on RHD cars should be on the opposite side in the engine bay.
https://www.golfmk7.com/forums/index.php?threads/psa-cable-tie-your-bonnet-release-cable-junction-box.365541/
Gone but not forgotten;
2016 Polo GTI; Blue Silk
Offline SuperScaff
« Reply #2 on: 12 January 2025, 14:27 »
Thanks buddy I’ve done the zip tie jobbie too
Offline uzinusa
« Reply #3 on: 13 January 2025, 21:48 »
A little copper grease is quite useful for latches and door hinges.
GTI PP 3 door, DSG, Carbon Grey Metalic, DCC, Keyless, Discover Pro
