Author Topic: MK7 wheels on MK8  (Read 8451 times)
Offline JG220
MK7 wheels on MK8
« on: 01 September 2024, 20:04 »
I have done a search and couldn't find anything conclusive.
I'd like to run a set of 18in winter on a MK8 Gti, I have found a set of 18 inch mk7.5 which have 3mm of additional ET, 48 vs 51. Thats like using a 3mm spacer.
Any experiences from a driving perspective, and I suppose looks too (can you tell).
Thanks for any view points!
« Last Edit: 01 September 2024, 20:53 by JG220 »
Offline SRGTD
Re: MK7 wheels on MK8
« Reply #1 on: 01 September 2024, 21:11 »
Which design of alloys are they?
I may be wrong but I thought the offset of all genuine VW 7.5J x 18” alloys for the mk7 / mk7.5 Golf was ET51. An offset of ET48 suggests they might either be replicas in the style of genuine VW alloys or if they are genuine VW, then they might be from a VW other than a mk7 Golf. If they are replicas, make sure you don’t pay over the odds for them - i.e. don’t pay the price that you’d pay for genuine VW alloys. Replicas might also have a different centre bore size to VW OEM alloys (VW centre bore is 57.1); if so, then you may find VW centre caps won’t fit.
One way to check if they’re genuine or not would be to ask the seller for pictures of the reverse side of the wheels. If they’re genuine VW, then they’ll have tell-tale markings cast into the reverse side of the spokes, such as VW part number, VW logo, the manufacturers name (probably one of Ronal, BBS or Borbet), the wheel spec details - diameter, width (the J size), and offset and usually a ‘JWL’ safety certification mark. There should also be a  ‘KBA’ certification number on the face of the wheel on the edge / rim - usually near the valve stem hole (KBA certification means the alloys meet all the safety requirements established by the German Traffic Laws and is a mandatory certification for alloys sold in Germany - which genuine VW alloys for the Golf will be).
As for the difference in offset; IMHO I very much doubt you’d notice.
Gone but not forgotten;
2016 Polo GTI; Blue Silk
Offline Carlosfandango
« Reply #2 on: 01 September 2024, 21:34 »
Mk7 18” are ET49 I believe, MK8 18” are ET51, but there could well be a mk7 ET48 wheel of some design out there, probably ET49 though.
Current -
Gone -
2022 Mk8 GTI DSG, Kings Red.
2003 Mk4 R32, Reflex Silver.
1991 AX GT.
1984 Mk1 XR2.
Plus many more.
Offline JG220
« Reply #3 on: 01 September 2024, 21:49 »
Thanks SRGTD,
I'm sure they are genuine, they have those markings. Seems that all MK7 Golf 18s are ET49 (I think I meant 49 earlier) and all MK8 18s are ET51.
PCD same, as well as rim width.
« Last Edit: 01 September 2024, 21:54 by JG220 »
Offline JG220
« Reply #4 on: 01 September 2024, 21:53 »
Ah yes:
Offline SRGTD
« Reply #5 on: 02 September 2024, 00:35 »
Thanks SRGTD,
That’s good to hear.
Offline Dogman12
« Reply #6 on: 02 September 2024, 03:21 »
Which ET has 19" Golf Estorils? 51 ?
« Reply #7 on: 02 September 2024, 05:56 »
Genuine 19” Estorils are ET50.
Current -
Gone -
1991 AX GT.
1984 Mk1 XR2.
Plus many more.
« Reply #8 on: 02 September 2024, 06:00 »
Thanks SRGTD,
There are exceptions when it comes to Mk7 or Mk8 18” offset, but in general they are as stated above.
Current -
Gone -
1991 AX GT.
1984 Mk1 XR2.
Plus many more.
Offline Rudedog
« Reply #9 on: 02 September 2024, 12:24 »
Well the VW 18" Prets I have are ET51 - but I guess they can't be classed as standard.
