Author Topic: mark 1 gti conversion to mk2 1.8 16valve  (Read 1765 times)
Offline bigbob
« on: 23 October 2005, 15:50 »
hello there does anyone know where i can get details on the above engine conversion????? ie step by step guide???
cheers peeps
Dinky
Re: mark 1 gti conversion to mk2 1.8 16valve
« Reply #1 on: 23 October 2005, 17:26 »
Dinx :kiss:
Offline gibby
« Reply #2 on: 24 October 2005, 10:44 »
Welcome to the forum.  :smiley: For details on engine conversions then somewhere like vwvortex website is probably agood place to start. There's some 1.8T conversion links in the garage section, but not 1.8 16V.
......now officially dubless.
Offline Rhyso
« Reply #3 on: 24 October 2005, 12:51 »
howdy!!  :cool:
welcome to the forum!!  :smiley:
Offline Mk1Mad J - 16v
  • At my age I don't have to act responsibly...
« Reply #4 on: 26 October 2005, 15:29 »
Hello & Welcome, i'm doing the same conversion, although i'm using a scirocco 16 inlet manifold to keep the fuel lines on the right side and for a factory look, i should have some pics etc soon, in the meantime here's my parts list so far:-
Fuel System
(Airbox-not too important) metering head/fuel distributor Fuel Injectors with fuel lines
Engine Electrics
Ecu & loom & sensors (knock sensor etc..) Distributor & ignition leads & coil
Engine Ancillaries
Starter Motor/solenoid & fittings
Alternator & fittings
Brakes (entire front system)
Servo & master cylinder
hubs/bearing/carriers/callipers/pads
Others
Gearbox
Exhaust manifold & downpipe
Water pipes/hoses
oil breathers/vacuum lines etc..
Speedo & rev clock
Its all a pretty straighforward swap apart from the exhaust system, you can get specially made manifolds for the conversion startring at about £220. but I'm going to cut and shut my mk1 downpipe to the 16v downpipe and just use the 16v manifold as i'm planning to fit a turbo next and that's going to need an entirely different manifold.
"Ever since I started to surf, I have realized that golf is for people who don't know how to surf."  -- Tiger Woods.
my dub project:-
http://www.golfgtiforum.co.uk/index.php?topic=35338.0
http://www.youtube.com/watch?v=WyEUOoH_xxo
