Author Topic: MK8 GTi some issues heating/loss of power etc help needed  (Read 5302 times)
Offline BingVW
Hi all,
Soooo I've had the new GTi since November and it's been amazing to drive we've done about 8K miles in it since delivery. The car over the last 10 days seems to have developed some issues these are:-
Change in brake pedal feel, the peddle seems to a softer then normal
Loss in pick-up from 3k revs upwards
Warm air blowing air from vents, even if heating is turned off
Any ideas on what can be causing these?
Thanks
« Last Edit: 19 June 2024, 16:08 by BingVW »
Mk2 16v GTi - Past
Mk2 VR6 transplant - Past
Mk8 GTi  Moonstone grey- Current
997 Turbo manual - Cobolt Blue- Current
Offline fredgroves
Re: MK8 GTi some issues heating/loss of power etc help needed
« Reply #1 on: 19 June 2024, 16:18 »
Sounds like 3 different problems to me.
Brakes sounds like brake system problems (fluid, pads or whatever)
Engine pick up is probably some sort of sensor problem somewhere
Aircon is probably also something weird sensor wise
Have you scanned it with a diag tool?
Any which way, it sounds like it needs to go back to the dealer...
Offline davo245
« Reply #2 on: 19 June 2024, 22:11 »
Hi all,
Thanks
Just take it to dealer warranty should start all 3 issues.
Mk6 GTI DSG
MK7.5 GTI performance DSG
Mk8 GTI
Offline BingVW
« Reply #3 on: 20 June 2024, 11:58 »
Yep booked into be looked at.
I can't need new brakes at 8K miles, my wife is the main driver and she drives it sloooooowwwwww and in economy mode :rolleyes:
Mk2 16v GTi - Past
