Author Topic: 7.5 gti  (Read 4598 times)
Offline mossy69
  • 2014 Gtd carbon grey pro nav dyn audio keyless wp
7.5 gti
« on: 17 May 2024, 18:44 »
hi there I'm looking tomorrow at a 7.5 Gti I understand there a timing chain , is there any other faults I should be looking for , I'm currently driving a 2014 Gtd pro nav and dyn audio there for is the sound system any good , also any other issueshttps://www.autotrader.co.uk/car-details/202404178766204?sort=relevance&advertising-location=at_cars&make=Volkswagen&model=Golf&page=7&postcode=ne23%207rs&price-from=15000&price-to=27500&radius=60&fromsra
2021 Gti moonstone grey 19 Adelaide HUD winter pack
2014 GTD carbon grey pro nav dyn audio keyless
Offline GKR47
Re: 7.5 gti
« Reply #1 on: 18 May 2024, 11:41 »
I advise you check out the service history and the warranty.
Non VW warranties do not often cover a labour rate for repair by a vw dealer.
Car looks fine though.
Offline SRGTD
Re: 7.5 gti
« Reply #2 on: 18 May 2024, 12:36 »
@mossy69; Three of the alloys (all but the front offside alloy) have white worm corrosion, so you could get the dealer to get them refurbished or alternatively budget for around £120 -£140 per wheel to get them done yourself (use it a negotiating point to get a discount off the price of the car if everything else stacks up).
The non tartan sections of interior upholstery look quite grubby in places (white stain marks); get the dealer to clean it properly. It disappoints me when a car’s not prepared to what I would consider to be an acceptable standard prior to photographing and advertising for sale. :sad: :angry:.
Check that the DSG service has been carried out; it should have been done at 40k miles. Also, check the tyres; from the MOT checker on the government website, both front tyres at the last MOT (Dec 2023) were close to the legal limit.
I can’t remember seeing reports of timing chain issues on the mk7 /mk7.5. There were issues with the timing chain tensioner on the mk6 GTI and the tensioner went through a number of revisions during the mk6’s lifecycle. I’m assuming that lack of reported problems with the mk7 / mk7.5 is an indication that the tensioner used in the mk7 / mk7.5 is fit for purpose.
Good point by @GKR47 about warranty; the dealer selling the car is a Renault dealer, so any warranty won’t be a VW warranty.
Potential issues I’m aware of with the mk7 / mk7.5 GTI;
  • a weak point with the EA888 2.0 engine in the mk7 / mk7.5 GTI is the water pump / thermostat housing, so check for signs of leakage and / or low coolant level in the cooling system expansion tank. The car’s service history may show whether or not the water pump / thermostat housing has been replaced.
  • there’s been a few instances of the silicate bag in the coolant expansion tank splitting, causing blockages in the heater matrix. Not all cars have the silicate bag (usually indicated by ‘Mit Silicate’ printed on the outside of the expansion tank). If you use the forum advanced search facility, you should find discussion topics relating to this. From memory, blocked heater matrix seems to be more of an issue with diesels, so probably not a major issue.
  • rear door speaker seals can leak, allowing water ingress into the rear footwells; carpets for dampness.
  • water ingress into the boot / spare wheel well. Possible causes;
    a) grommet on the end of the tailgate handle drain tube can perish, allowing water to collect inside the tailgate and drain into the boot / spare wheel well
    b) defective seal around air pressure equalisation vents (located in lower rear quarter panels behind rear bumper cover)
    c) perished seals around rear light clusters
    Check boot floor and spare wheel well for water.
Gone but not forgotten;
2016 Polo GTI; Blue Silk
Offline Big Col
Re: 7.5 gti
« Reply #3 on: 18 May 2024, 16:26 »
assuming everything else checks out ok - my focus would be on the common water pump / thermostat issue.
I'd be asking specific questions if it has been done - evidence for this? - and will any warranty provided cover the issue if it arises.
The budget ditchfinders on the front would also annoy me. I went from a GTD to GTI and one of the major differences is just how much sharper the front end is on the GTI. Those tyres could potentially ruin that.
Current - 2019 Golf GTI
Previous, 2016 Golf GTD, 2014 Leon FR, 2010 Ibiza FR, 2006 Fabia vRS , various Vauxhalls
